Using 85mm SLP MAF with STS
Old 08-11-2009, 11:28 PM
vipvegas's Avatar
Default Using 85mm SLP MAF with STS
Is there any benefit over stock running with with FI 383 stroker?
Old 08-12-2009, 10:47 AM
vipvegas's Avatar
ttt anyone
Old 08-12-2009, 10:53 AM
knappbunch's Avatar
With an sts kit eliminate the maf and goe 2 bar map speed density. the maf will eventually fail from oil even if you have the restrictor in the scavange line.
Old 08-12-2009, 11:44 AM
RooRnZ28's Avatar
stick with the stock MAF if you have to keep it
Old 08-12-2009, 12:02 PM
allthrotle's Avatar
Yes use the stock maf if you still have it.
Old 08-12-2009, 02:40 PM
vipvegas's Avatar
still got the stock maf.. will use it and yes knappbunch is right it gets oily quick.. Is the 2bar map speed density a better way to go period. What parts will I need. Im in the middle of the rebuild and will eventually get a tune.
