car dies when I give it throttle
Old 08-13-2009, 09:32 AM
streetassasin's Avatar
Default car dies when I give it throttle
It will idle fine at 950rpms but it I even tap the gas it drops down to around 500 and dies unless I take my foot off the gas, it has a brand new walbro pump with maybe 150 miles on it and has worked flawlessly until now. Im thinkin fuel filter might be clogged and is starving it of fuel. Any ideas?
Old 08-13-2009, 09:45 AM
Ice78Transam's Avatar
Thats strange, Could be a badly clogged filter. Sometimes the extra push from an aftermarket pump can really jazz up an old filter. Its obviously not the fuel sock so check the inline filters and the engine compartment one as well. worst comes to worst, it was just some maintenance that should have been done anyway.
It certainly doesn't sound like a voltage issue because it had worked properly.
Old 08-13-2009, 09:49 AM
thanks man, I have no idea how old the filter is, I bought the car a week ago and the pump went out the same day I bought it had to overnight a pump kit from tsp ended up around $200 after tax and shipping
Old 08-13-2009, 09:55 AM
Oh, and make sure to use a rag around all the fuel lines when disconnecting the fittings/banjo bolts. Otherwise you get a complementary coat down of sex panther...
Oh and your car is tuned to idle at 950, right?
Old 08-13-2009, 02:38 PM
ok I changed the filter it helped some but still tries to die and breaks up bad above 2500 rpm
Old 08-13-2009, 02:51 PM
NC98Z's Avatar
Time to go by your local Autozone and get them to see what trouble codes your CPU has stored. They do it for free and you'll have something to go on.
Old 08-13-2009, 02:53 PM
Im about to run and get the throttle body off my wrecked ss thinkin it might be the tps sensor. If not Im gonna pull the pump out and double check the connections
Old 08-13-2009, 03:00 PM
SOMbitch's Avatar
Congrats on getting back in a f-body
I would check fuel pressure before I yank the pump. It wouldn't be the first new Walbro to crap out
Old 08-13-2009, 03:08 PM
andrew69_04's Avatar
stop giving it gas and it wont die
Old 08-13-2009, 03:28 PM
the_merv's Avatar
I'd give mine gas and plants would die..lol
I would check the codes like mentioned.
Old 08-13-2009, 05:03 PM
thanks for the ideas guy but I got it fixed, it turned out I didnt tighten the clamp on the fuel line coming from the pump in the tank all the way and line was slipping off, I tighted it back and it is working great now
Old 08-13-2009, 05:04 PM
thanks man, this one pulls on motor like the ss did on nitrous
Old 08-20-2009, 02:44 AM
F-BodyMind's Avatar
I had this same problem with two cars ive owned. The first was a 91 TA And it turned out to be a bad fuel injector. The other one was my 96 Z28 and that turned out to be the blaster coil.. Both codes read for a cylinder misfire.
Quick Reply: car dies when I give it throttle
