Do I need to get manifolds coated?
Old 08-13-2009, 11:16 AM
vipvegas's Avatar
Default Do I need to get manifolds coated?
Should I coat these with something before doing header wrap back with my sts kit.
Old 08-13-2009, 12:18 PM
pwrtrip75's Avatar
Stock manifolds? If you want them to look pretty sure.
Old 08-13-2009, 12:27 PM
XtremeDime's Avatar
Wrap? Pretty? I didnt know it was pretty to mummify your manifolds lol
Old 08-13-2009, 12:31 PM
Josh@KY-Turbo's Avatar
Hight Temp VHT spray can them. They are rough enough that the coat pretty well and the coating doesnt flake off. I have done several sets like that with great results.
Old 08-13-2009, 12:32 PM
XtremeDime's Avatar
Would you recommend that stuff for charge piping aswell?
Old 08-13-2009, 01:06 PM
I did it on my own rides. It flakes after a while. I usualy spray the pipes. Wrap them. then spray the wrap. On my personal junk its all about function before form.
Old 08-13-2009, 01:31 PM
99Z28LS1's Avatar
I had my stockers ported and coated to help hold in as much heat as possible with my STS kit. Wrapped everything from flange back to the turbo as well.
Now I'll be using Josh's kit and getting the whole hot side coated and wrapped to make it that much better
Old 08-13-2009, 01:44 PM
DeltaT's Avatar
If you wrap over coating it will destroy the coating in short order. You can wrap over paint, then (as mentioned) paint over the wrap with hi-temp, but don't put wrap over anything you have coated - it will flake and rust very quickly.
Jim
Quick Reply: Do I need to get manifolds coated?
