What is a rear end?
I will assume you are serious.
The entire rear axle assembly between the two rear tires. ALL F-body rear ends totally suck as a result of small diameter gears that are prone to breaking when the motor is hopped up. They even break on stock motors more than they should.
GM did this to reduce cost and stretch MPG's.
The housing, the axles inside of it, the center cap with pinion yolk, and the gears inside of it = the rearend. Brakes and brake lines are attached to the rearend.
When I first started learning, I didn't know the difference between a rearend and a differential.
