delay ?
delay ?
hitting the track this sunday and was curious what you guys think will be a good starting point for the delay off of the line? i want it to come in after the clutch is fully engaged. i was thinking that i would start out with a full second. any thoughts?
1.5, hell you will be out of 1st gear by then. the point will be to add as much as you can as soon as you can before shifting to second. If you must have a delay, it would be under a 1/2 second. the above advice must be from auto drivers, lol. i dump mine basically also and even if spinning thru the entire 1st gear will still 60 better than no spray.
Robert
Robert
