Bigger cam qeustion
Old 08-14-2009, 06:22 PM
copteezer496's Avatar
Default Bigger cam qeustion
Ok, I had a Comp Cams 236/236 585/585@112LSA. I had a lifter crap out and destroyed the cam. So I called Comp Cams and told them i was going bigger and they recommend the 281/289 617/624@113LSA. I talked to a guy yesterday that said that I need to "Fly Cut my pistons" in order for the cam to work. I was wondering how true this is. If so/not, what all do i need to do in order to run a cam like that with a stock bottom end and stock valves?
Old 08-14-2009, 06:35 PM
MUSTANGBRKR02's Avatar
I wouldn't run that cam on stock 98 heads might be choking it down.
Old 08-14-2009, 06:39 PM
What's a good size to run?!
Old 08-14-2009, 06:44 PM
danhr's Avatar
what are the specs at .050"?
Old 08-15-2009, 02:09 PM
That cam was in the car when i bought it so I'm not sure.
Old 08-15-2009, 02:16 PM
USArmyZ28's Avatar
holy **** @ duration. You will more then likely have to fly cut and I wouldnt recommend running a cam THAT big.
Old 08-15-2009, 04:10 PM
quick346's Avatar
thats prob @.006 so it should be a 231/239 @.050 that would be a good cam.
out of all the cams i have ran on my 346 the best all around cam was a xer 281 232/234 .587/.589 on a 112+2 had explosive mid range but still pulled past 6500
Old 08-15-2009, 04:32 PM
oldguy99Z's Avatar
Yea if you called Comp they recommended a cam at advertised duration (at .006").Thats a bigger number than at .050".Like quick346 said-looks like Comps lsr lobes 231/239.That should be a good cam.
Old 08-15-2009, 06:01 PM
I thought that had to be something wrong in communication, because that duration would be unbearable at .050"
Old 08-16-2009, 01:23 PM
JPH
JPH's Avatar
Run it. Your fine, unless heads have been milled.
Old 08-16-2009, 01:42 PM
gold98Z28's Avatar
the answer to your question is NO BODY KNOWS unless they degreed THAT cam in YOUR engine and checked PISTON TO VALVE CLEARANCE. do yourself a favor and check ptv clearance no matter what anyone tells you. if its gonna be close, it NEEDS to be checked. period
Old 08-16-2009, 01:44 PM
gold98Z28's Avatar
oh and to clear up any confusion on the numbers as some have already noticed his current cam specs are @.050 numbers vs advertised duration numbers from comp on the new cam.
