WTF? LS6 block in a '99?
Old 08-14-2009, 06:48 PM
Rickenbackerman's Avatar
Default WTF? LS6 block in a '99?
Getting started on doing a boatload of mods, including LS6 valley cover and PCV setup. I pull the stock valley cover, look for the part that has be cut away sending aluminum shavings flying everywhere, and low and behold it's not there! Also, no ribs in the valley and no bulls-eye on the front of the block. Anyone know what I'm dealing with here? 1999 formula WS6, build date June '99. Off to see if I can read the casting number...
edit: no motor swaps, bought the car brand new...
Old 08-14-2009, 07:14 PM
2001SS_stompinsupras's Avatar
they didnt even make LS6 until 2001
Old 08-14-2009, 08:37 PM
jetlag's Avatar
lol
Yeah you might want to check the casting number...
My 2002 has an LS6 block
Old 08-14-2009, 09:15 PM
Tried reading the casting number 6 times with a mirror and flashlight, it's impossible... first time I got 112608? and then 1?5608?..
Maybe when I pull the trans to install my converter I can tilt the motor back and get a better look at it.
Regardless, did any LS1 blocks NOT have the part that needs to be ground away for an LS6 valley cover and have no ribs in the valley?
Old 08-14-2009, 10:28 PM
phoenix1987's Avatar
I hate you. I have a 01 block and had to cut that bastard notch out in 92 degree heat for my valley cover. lol
Old 08-14-2009, 11:36 PM
Sharpe's Avatar
I have a complete LS6! Well, thanks to EPP anyway...
Old 08-14-2009, 11:46 PM
DaveX's Avatar
The LS6 block is not really anything to get excited about but it wasn't even available in 99.
Old 08-15-2009, 12:43 PM
I'm really only excited about the fact that I won't be sending billions of minuscule aluminum particles all over my engine bay while cutting off the chunk for the LS6 valley cover.
So has anybody seen an LS1 block that looks like this?
Old 08-18-2009, 02:42 PM
Nobody?
Old 08-18-2009, 02:47 PM
01_torch_red_vette's Avatar
when i did my heads and cam swap on my car i put on an ls6 valley cover and pcv system. i didnt have to notch mine, but i dont know if my block was an ls6 block or not either
Old 08-18-2009, 03:08 PM
socal's Avatar
i would think its nothing more then an early style block with it not having the ribing for support bracing and the lifter bay windows for better breathing
