battery wiped! new battery wiped out too, and NEW alternator wont charge
Old 08-15-2009, 04:06 PM
kamarobuddy's Avatar
Default battery wiped! new battery wiped out too, and NEW alternator wont charge
So i just got my head/cam combo done and took it to the strip. after the first pass the voltage on my battery was completely depleted. I decided to go into town and get my alternator checked and the car died on the road with i was going 60mph. NO power steering no power brakes... NOTHING! After walking the remainder of the way on foot into town I bought a brand new battery and NEW alternator and waited for a ride. Got them in the car the next day and the car ran fine for like a day. The battery is on like 9 volts and the alternator is not seeming to charge it. At this point i am pissed, frustrated and broke for the rest of the week. I would greatly appreciate any input or advice form the men and women here at ls1tech! Thanks for reading the post and for any and all advice! ~Dustin
Old 08-15-2009, 05:07 PM
Sharpe's Avatar
Moved from Advanced Tech to General Maintenance.
Old 08-15-2009, 06:00 PM
LS6427's Avatar
excitor wire
It plugs into the top of the alternator (tiny little sumbitch) and when you start the car the PCM commands the alternator to start charging via that little wire.
Check it out, they wear out and get damaged very easily.
ebay has them for $10.00. Splice it in with butt connectors and shrink wrap. Don't solder it.
http://cgi.ebay.com/ebaymotors/LS1-A...Q5fAccessories
Old 08-16-2009, 07:56 AM
fleetmgr's Avatar
Originally Posted by LS6427
Don't solder it.
Why not?
Old 08-21-2009, 06:48 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Originally Posted by fleetmgr
Why not?
My guess, because it would / could change the voltage that the pcm sees due to resistance at the solder joint. Technically, if you were to do it right, you would replace the entire wire, going from the connecter at the alternator all the way back to the pcm since from the factory it is that way. It's one solid wire, with no connections or splits.
Old 08-21-2009, 08:23 AM
fleetmgr's Avatar
But a butt splice will have a higher resistance than a properly soldered connection as long as it's not a cold joint, although the difference probably wouldn't be measureable without going to at least 3 decimals. The solder joint however will be a stronger mechanical connection.
Old 08-21-2009, 08:55 AM
jmilz28's Avatar
Use a new pigtail connector, solder it, heatshrink it - good to go. This is an OEM acceptable repair process. Regardless, make sure you heatshrink the connection and use a few extra inches of wire.
Old 08-21-2009, 11:41 AM
1 FMF's Avatar
then what about all the solder joints on the printed circuit boards in the PCM?
Old 08-22-2009, 10:00 PM
UNDER PRESSURE MOD
I wasn't saying he was correct about soldering it, I was only GUESSING what the poster meant when he said to use crimpt connectors.
Me personally, I'd replace it with a single wire from the alternator to the pcm and not risk using a connection.
