MAF improvement
MAF improvement
I've asked a similar question concerning the MAF before, but since I havn't completed my FI tune and it would be a "do it now or not at all" situation should I toss my stock size (early style) MAF and go with a larger 85mm ZO6 MAF, a truck MAF, or maybe a Delphi MAF that actually came with the procharger.
If it was just a drop in, it would be a no brainer, but when you consider the purchase cost of a MAF (unless I use the Delphi) different hose adapters, and the cost of the wiring harness to seperate the IAT, I need to know that it's worth doing.Is the Delphi unit any good (I already have it)
I'm running a P1SC1 at around 9psi and 600+ hp
Thanks guys
Thanks guys
Coal Mining Director
IMHO that if you're going to stay at 9psi or less, I'd leave the stock maf in it. I retuned a LPE TT a while back and rebuilt the VE table for 42's. Enabled the stock maf and it fell in line. RPM vs PE was dead on....but it was limited to 8psi and 540rwhp on an eddy current dyno...."should" be around 580-600 on a DynoJet.
That's my personal limit...beyond that throw the maf away and put a 2bar map/tune in it.
Thanks guys
I have thought hard and read a LOT of post about SD, but I think the only thing that makes me want to stay with the MAF, if possible, is the temp/humidity versatility. "Down here in GA" It may be in the 30s one day, and back in the 70s two days later. I want the car to be as low maintenance as possible (or as least as low as a boosted motor can be) and not have to swap out tunes for the seasons. If I was going for higher hp, then I might not have a choice.
If there's anything to gain from going to a LARGER MAF, then that's easy enough to do, but SD might have to wait until I get a lot better at tuning myself.
That's very interesting. I must confess I've probably read well over 100 post on SD vs MAF tunes, and although there have been major disagreements on everything from MAF limits to SD benefits, I have never heard anyone say that one of the benefits of SD tuning was it compensated well for different weather conditions. In fact, some of the biggest advocates of SD tunes, state that they simply have "several tunes" loaded so that they can simply "take a few mins. " and download a tune to fit major temp changes. One guy even stated that he had a winter and summer tune.
I'm not saying that ANY of this is fact, and it may simply be in the quality of the tune, but it's just what I've read for several months.
I would like nothing better than to drop my maf and go SD. It would even make my filter mounting easier since the corner of my filter hits my MAF; but the two tuners I deal with (One is a WELL known tuner) have both advised me (meaning they don't want to do it) against going SD until my MAF limits me.
The MAF adjusts slightly better for weather changes but that's really the job of the O2s. Run it in OLMAF or OLSD and you'll be retuning often. Either of them in closed loop will be corrected just fine for the weather.
The real problem is the bias table the over adjusts for IAT temp.
7 Second Club
A MAF is always going to be more accurate than SD as long as you are not maxing out the MAF in the process. It's a device that actually measures the air flow/density unlike SD which is a calculated value. I usually only suggest people go SD when it's necessary ie maf is maxed out. You give up a few diagnostic functions that are helpful when you go SD. For your setup I would give the stock MAF a shot and as long as it isn't maxed out run that.
Neither are going to completely compensate for weather changes, that's what the O2s are there for. There are some functions that you lose when going SD only but there are enhanced PCM operating systems from either HPTuners or EFIlive that give you back the features that you lose and offer some other benefits as well.
7 Second Club
Not always. MAF doesn't measure the airflow it measures the elecrtical frequency required to maintain the temp of the heated elements in the sensor. Then it takes that value and compares it to a table of airflow numbers that have been put in by the end user. Much the same as how the VE tables works.
Yea, I know that. However you lose misfire diagnostics which come in very handy at times, you don't get that back with a custom OS. Then there is the issue of some states emissions requirements...
