Top Bolt on bell housing Help
Old 08-15-2009, 08:55 PM
equalizer's Avatar
Default Top Bolt on bell housing Help
I am in the process of installing my new PerformaBuilt 4L60E T3 trans into my '02 Camaro. The top bolt or #7 bolt on Bell Housing is kicking my butt.
Yes, I am a rookie.
Anyone have any suggestions on how to reach this bolt?
Tried tipping engine up and down without success.
I am at different e-mail address graundsmaster@montanasky.biz or
406 885-3281.
Old 08-15-2009, 09:06 PM
97BlackLT1TA's Avatar
I used an extension that put the ratchet behind the tailshaft of the trans.
Old 08-15-2009, 10:11 PM
CayenneRedV6's Avatar
I had my intake off while I did mine and I could reach the bolt from the top. But usually you have to use a swivel thing and a really long extension.
Old 08-16-2009, 08:11 AM
tals7's Avatar
Smile
super long ext with swivel.i did my 4l85e this way.
Old 08-16-2009, 09:12 AM
Badazz 97 TA's Avatar
Yes, I am a rookie.
406 885-3281.
some guys remove the intake. just some swivels and extensions should work. When you go to bolt everything back, just leave that bolt off. Since you will be removing that trans at least 3-4 more times in the next few months to come
Old 08-16-2009, 10:04 AM
WE TODD DID's Avatar
Swivel socket and long extension.
Old 08-16-2009, 10:15 AM
01ssreda4's Avatar
before you install the tranny, Choose a few select areas to precision clearance with a mini sledge
Old 08-16-2009, 06:16 PM
equalizer's Avatar
Default Top Bolt tp Bell Housing
Badazz 97,
I do not know if I want to know why I will be removing this transmission several times in the next few months. But lay it on me. I need to know.
Also drove the car and applied the brake very lightly and I could not feel any difference with the stall. Looks like I need to food with the tune some more.
Old 08-16-2009, 06:26 PM
tals7's Avatar
Smile
i think he is talking about your 4l60e.
Old 08-16-2009, 07:17 PM
Marc 85Z28's Avatar
All 3/8" drive. Use a 13mm shallow socket with a separate universal extension. Use that with at least a 24" extension. If you get the integrated socket and universal it doesn't provide enough articulation. The top bolt in these cars is cake compared to transmissions in other makes.
Old 08-16-2009, 07:30 PM
tals7's Avatar
Smile
i used 13mm snap-on swievel.it fit in there just had to use two hands.
