LS1 year model?
Old 08-16-2009, 10:54 AM
DeanJ's Avatar
Default LS1 year model?
Guys, my first post over here, so here it goes. I recently purchased a LS1 to swap into my third gen Camaro. The question is how do I tell what year it is? I did some searching and found out it is possibly '99 or 2000. It has a 2 wire CTS an EGR system and the service# on the PCM is 09354896. Can anyone here confirm. Thanks in advance, Dean.
Old 08-16-2009, 01:40 PM
NemeSS's Avatar
if valve cover are center bolt its 99-00
perimeter is 98
01 and 02 came with out egr and ls6 intake
the front of the block will have the yr cast into it around the wp bore area
Old 08-16-2009, 04:09 PM
poconojoe's Avatar
If you got the correct PCM from the vehicle it will have the vin in it
Old 08-16-2009, 05:21 PM
DeanJ's Avatar
Thanks for the quick replys, it looks to be a '99 or 2000. I will check the block tomorrow. I think the PCM to be correct. My tuner will be able to check VIN, correct? Thanks again, Dean.
