oil leak?
Old 08-16-2009, 04:26 PM
TXZ28LS1's Avatar
Exclamation oil leak?
hey guys, i noticed my car is dripping little bits of oil. i rarely drive the car, as it just sits in the garage. i checked my engine oil level and its perfect, and the oil pressure is perfect. i would say its maybe a drip or 2, but by the end of the week its a little bit bigger than a quarter size puddle? any ideas?
Old 08-16-2009, 04:37 PM
Grendel123's Avatar
I notice that if I don't drive the car for more then a few days it starts to drip. I am wondering if there's a gasket or seal that is dried out and needs to be replaced...kinda hoping that's what it is too. Of course I'm not too knowledgable in these areas.
Old 08-16-2009, 07:10 PM
TXZ28LS1's Avatar
thanks grendel. im wondering if it might be oil drain plug. but it seems fine. just wondering if anybody knows?
Old 08-17-2009, 09:02 AM
91RS383's Avatar
Nobody can tell where your leak is coming from but you. You need to get under the car and trace the oil back to its source. Good luck. Post up when you have more info and you'll get more help.
TXZ28LS1's Avatar
anyone with any ideas?
Old 08-17-2009, 09:07 AM
fleetmgr's Avatar
Could be any one of a number of things - valve cover, drain plug, rear main seal, timing cover seal, oil gallery plug, cam plug, etc. etc.
Hence the comment from 91RS383 about looking for it.
Old 08-17-2009, 09:14 AM
TXZ28LS1's Avatar
yeah its a pita trying to track down where its coming from. i appreciate it. ill try to take a look today. seems like its little drips of oil though.
Old 08-18-2009, 01:28 AM
masterz28's Avatar
Mine was the rear main seal, since my tranny went out and is getting done I am getting it the RMS fixed so it wont leak anymore, yay.
Old 08-18-2009, 08:24 AM
dragonrage's Avatar
Look for oil trails on the engine. If it's too dirty then use some engine degreaser and get it all looking decent so next time you'll be able to tell where the oil's coming from.
If you keep your car parked in a flat, clean spot (meaning no prior oil drops on it) then you can use that to help tell where the leak is - if you don't move your car then your leak should be from somewhere in the area of where the spot is.
Old 08-18-2009, 11:24 AM
TXZ28LS1's Avatar
thanks dragonrage!! its weird cuz i put some paper towels underneath the car and let it sit there for 1 day, and i checked this morning and the towels were clean as a whistle.
Old 08-18-2009, 11:43 AM
dragonrage's Avatar
Of course... Can't go and make things easy on you, now can it?
Be assured that the moment you remove the towels... drip!
Old 08-18-2009, 11:50 AM
TXZ28LS1's Avatar
im sure man, that once i remove those towels here comes the drips..lol..
Old 08-18-2009, 12:45 PM
91RS383's Avatar
If your leak is above the oil pan, it's a good possibility that it only leaks when the engine is running. Start her up and let it idle over the paper towels to try and find the leak.
Old 08-18-2009, 12:59 PM
TXZ28LS1's Avatar
thanks man!!! ill give that a try. i appreciate all the info guys.
