Anybody running dynatech headers??
The speed shop doing my work recommended them and I see most of yall running kooks or arh. I wanted stainless steel and they said that this was a good header system with ory...1 3/4 size. Any reviews positive or negative and also how is ground clearance??
Call ARH 631.608.1986 we will set up with a great pair of headers and you won't have to worry about anything after that as far as fitment, ground clearance, or quality.
Anthony
Anthony
I run Dynatech Supermaxx headers/y-pipe... very well made, very good fit, very easy install, very good ground clearance...
does bang on tunnel brace (bend it a little or remove it).
I have their header system, it fit well and I like them. The only problem i have had is keeping the collectors from leaking, and thats a pretty common problem with most collectors. You did good, i think you will be happy with them, good luck with the car, be careful over there.
