Long wheel studs with street tires??
Old 11-23-2003, 07:56 PM
theblur98ss's Avatar
Default Long wheel studs with street tires??
I just got a 9" rear and it came with the longer studs. Their nice for racing but what do you guys do with your street setup? When are the longer studs manditory at the track. They look pathetic sticking out of my chrome rims.
Old 11-23-2003, 11:39 PM
NiceTry's Avatar
just buy another rearend with the shorter studs then you can swap them out! or you could just but some regular stud if you want and put them in
Old 11-24-2003, 07:25 AM
Restricted User
2001 Pewter WS6's Avatar
Buy another rear end... What kind of stupid advice is that?
I don't think you need the longer studs until you get into the 9's. IHRA isn't as strict as NHRA. They just want to see open lugs so that they can see the studs. Change the studs for the shorter ones. They are more concerned about a cage than they are for long studs. The rule states that the stud must go at basically at least 1/2 way into the hex head portion of the lugnut. You must use open end lugnuts with aftermarket wheels.
Old 11-24-2003, 09:23 AM
8 second mod
Noyzee's Avatar
What kind of wheels do you run on the street?
Summit makes a decent open acorn style nut that works, they are cheep to. But with stock wheels no good, the center caps wont fit.
Then the only fix is shorter studs.
Old 11-24-2003, 04:19 PM
ShadowZ28's Avatar
Take a look at this link https://ls1tech.com/forums/showthrea...ighlight=studs
Joe
Old 11-24-2003, 09:59 PM
roy
roy's Avatar
If you do decide to use a spacer ,ensure it is hubcentric and not a generic universal spacer, . the weight of the vehicle must rest on the hubcentric and not the studs or else the studs will fail.
Old 11-24-2003, 10:14 PM
Classic's Avatar
With those ARP studs you can still use the factory plastic caps if that is what you are using. You can also get a set of long chrome or regular style lugs from Gorrila.
Old 11-25-2003, 09:24 AM
8 second mod
Noyzee's Avatar
I know it would work on those, but ss rims,z28 rims it wont, they have center caps with those stupid gm thread plastic nuts.
But ta, that looks good.
Old 11-25-2003, 09:38 AM
Formerly 4mulaJoe
LS1x2's Avatar
I've got 3" studs on the rear on mine with stock 16" formula wheels in the back for streeet duty. I use a generic acorn lugnut I got from oreillys and a long extension to put them on. I don't use the plastic things. Those kept falling off when the car was brand new anyway. The studs stick out past the centercap a bit.
Old 12-05-2003, 11:15 AM
SilverLS1's Avatar
Is there any way I could just cut off a little of each stud? That way, I have the strong studs, and the wont look rediculous with my ZR1's?
Old 12-05-2003, 03:31 PM
xaon's Avatar
I bought the longest 1/2" thread acorn closed-ended lugnuts available from gorilla lugnuts. I also use a 5/16" spacer behind my stock wheels to keep the lugnuts from bottoming out.
