need help with oil pan gasket plz!!
Old 08-17-2009, 10:47 PM
johnster's Avatar
Default need help with oil pan gasket plz!!
ok guys,,,, my oil pan gasket was leaking so i pulled the trans and droped the pan,took lose the pick up tube and the pan slid out, anyway i put a new gasket on it put it back 2geather and this dam thing is still leaking its *** off!!!! its come out around the bolts, in the back
need some help guys, did i over tighten the bolts????
Old 08-17-2009, 11:32 PM
jrpimp00's Avatar
probably what did you torque them down to? I know its different from the rest and easy to overtighten them
Old 08-18-2009, 09:46 AM
bigboykilroy's Avatar
Oil Pan Closeout Cover Bolt (Left Side) 106 lb in
Oil Pan Closeout Cover Bolt (Right Side) 106 lb in
Oil Pan Cover Bolts 106 lb in
Oil Pan Drain Plug 18 lb ft
Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft
Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in
Old 08-18-2009, 10:16 AM
EDS01SS's Avatar
does it leak all the time or just while or just after running? sounds like the rear main seal took a dump on ya
Old 08-18-2009, 01:44 PM
johnster's Avatar
i replaced the rear main seal it wasnt leaking. i replace it anyway cause i had a new one, its leaking from the sides of the pan bout half way back, it leaks bad when running but will some what stop after the motor has been off 4 a while.
Old 08-18-2009, 01:47 PM
johnster's Avatar
i tq them down my hand so i wouldnt overtighten them, its really blowing my mind!!!! i have replace many gaskets with no trouble
Old 08-18-2009, 05:32 PM
500@10psi's Avatar
hate to say it but i'd check for cracks
Old 08-18-2009, 10:06 PM
johnster's Avatar
****! what would be the best way to do that??
Old 08-19-2009, 10:05 AM
EDS01SS's Avatar
what side is it leaking from?if its the passenger side i would check the o-ring on the dipstick tube.
Old 08-19-2009, 08:44 PM
johnster's Avatar
could my oil pan be cracked in a few places? has this happen to anybody? ive had the oil pan off a few times. talking about small cracks that r very hard to see???
Old 08-25-2009, 01:16 PM
ninetynineta's Avatar
I did a cam swap on my car this weekend and had to drop the pan to change the oil pump..... after getting everything done I have a pretty good leak coming from right above the oil filter.... cant tell exactly where but it runs down and drips off the filter. I changed the filter thinking I had pinched the seal on it, but it still does it with the new filter.... im curious what you find out.....
Old 08-25-2009, 07:06 PM
crainholio's Avatar
How did you align the front and rear seal carriers? Last big leaker I worked on had the rear seal carrier installed waaaay too high on the block, leaving lots of room for oil leakage.
The inverse would also be true...install the rear seal carrier too low, and there's no way the oil pan would seal against the block skirts.
Old 08-25-2009, 07:09 PM
crainholio's Avatar
Aside from the seal carrier alignment issue I mentioned above, improper torque is a killer.
Aluminum parts + no torque wrench = fail.
As you're removing the pan and dropping $$ on another new oil pan gasket, you'll have time to consider the value of a good torque wrench.
Old 03-28-2010, 07:34 PM
memphis24's Avatar
aluminum hates too much torque for sure ive seen it tons of times on military vehicles
Old 03-28-2010, 08:02 PM
blue98Z's Avatar
No one asked if you prepped the surface good on the block and pan? We would assume that you have but it wasnt mentioned. Might try just a dab of silicone around the back corners or all the way around if you wanna make sure.
Quick Reply: need help with oil pan gasket plz!!
