which clutch/flywheel
Old 08-19-2009, 07:06 PM
Bjorne043's Avatar
Default which clutch/flywheel
My clutch is starting to slip in my 98 WS6 and I'm curious as to which set-up to go to.
I'm thinking based on price I may do the LS7 clutch or the spec-2 clutch.
With either of these do I need to replace the flywheel as well or is it possible to remachine the existing flywheel and use that?
Any advice is great!!
Thanks!
Old 08-20-2009, 09:01 AM
SPEC-01's Avatar
Bjorne, I replied to your PM and ask that you let me know if you have any further questions. I really think you would be quite happy with the Stage 2 and either your resurfaced stock flywheel (as long as this is the first time it has been machined) or our Steel offering.
Old 08-20-2009, 03:25 PM
davidws6's Avatar
Default Clutch n Flywheel
If ur ride is a daily driver, just resurface ur flywheel !
No need buying another.
