Strano sway bar bushing question.
I was just wondering what is the energy suspension part number for Strano rear sway bars? I tightened it down and torqued it to manufactur specs a couple months ago when I was installing it, and now there is some play in the bar when I yank on it makes a clcking like noise, the noise is als when i am driving it.
LS1TECH Sponsor
Do you have the old bars or the new bars? There isn't a specific Energy Suspension number.... You need a set of 22mm bar bushings if you need to replace them but there are two different sized brackets, I see to recall either work but I am not 100% sure on that anymore (since I never use them).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
That was a transition period. The bushings shouldn't be super tight, the bar has to move and not bind to work properly.
I guess I don't follow why you think there is a problem. Are the bushings lubed? Is there dirt between the bar and the bushings? I can't imagine what clicking noise would stem from with regards to the bar. It just pivots in the bushings.
__________________
