H/C/I Z06 buring oil and blowing white smoke
Old 08-20-2009, 11:11 AM
artist71's Avatar
Default H/C/I Z06 buring oil and blowing white smoke
My 02 Z06 with new H/C/I and forged bottom end is buring oil pretty fast and lots of white smoke comes out after I get on the gas hard..even when I stop at a light after getting on it there seems to be a lot of smoke. Any idea?
I did a search and found some info..but nothing with my setup.
Thanks!
Old 08-20-2009, 01:21 PM
RJB01camaross's Avatar
Sometimes a blown head gasket will cause a lot of white smoke. Does your oil appear watered down? Have you done a system diagnostic? If so what codes did you have come up?
Old 08-20-2009, 02:34 PM
matrik's Avatar
piston rings?
Old 08-20-2009, 02:51 PM
CroonerSS's Avatar
Thanks!
White smoke not steam or water?
Old 08-20-2009, 03:06 PM
artist71's Avatar
yeah..not steam for sure. It almost look like there is a fire coming out of my exhaust its so much. Its going to the shop tomorrow to see whats going in..it might just need a little work on the tune maybe..I hope.
Thanks!
Old 08-20-2009, 03:39 PM
TAtoad's Avatar
well white smoke is water. any oil or fuel would be a dark toned smoke
Old 08-20-2009, 04:31 PM
93306's Avatar
ive experienced the same problem after putting on a set of heads ended up being valve stem seals
Old 08-21-2009, 11:07 AM
2001ws6-500hp's Avatar
head gasket, my car did the same thing, two weeks later, boom
Old 08-21-2009, 11:36 AM
tribaltalon's Avatar
ditto.. i say head gasket.. oil is blue or gray smoke, gas is black smoke. DONT drive it anymore until you figure what the problem is!!! its alot more expensive to replace a whole motor then something simple like a headgasket!!
Old 08-21-2009, 03:09 PM
WARP211's Avatar
Its diffinietly a HEAD GASKET.!!! Basically the white smoke is coming from the coolant and its going into the exhust thats why you burn white smoke all the time.!!
Old 08-21-2009, 04:01 PM
yea its a head gasket but whys he burning oil?
Old 08-21-2009, 04:52 PM
matrik's Avatar
This is the exact problem I'm experiencing now. Do you get a big puff of smoke on startup sometimes? I ruled out headgasket since I'm burning oil, oil from an oil change was clean and not milky, and coolants levels are perfect.
Old 08-23-2009, 01:28 AM
WARP211's Avatar
It could be a couple different things but a head gasket will burn both if it's diffective. As for Oil it could be the rings, (it has a forged bottom end it may have not been properly built right or something),valve guides.
Old 08-23-2009, 08:59 PM
Kurtomac's Avatar
I had a friend back a while back forget to install a PCV check valve and it was just sucking in oil in the intake....going through like a quart every 500 miles...got that straightened out for him and he was good to go...could be something simply....just to confirm the heavy whitish smoke is on accel or decel or both?
Old 05-07-2010, 10:12 PM
Ford_Assassin's Avatar
I am getting the same thing after a LS6 intake swap on my cammed 6.0 LQ4...
Quick Reply: H/C/I Z06 buring oil and blowing white smoke
