Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
BBC 496 3,000 LBS bird
Old 08-20-2009, 12:07 PM
tickey8's Avatar
Default BBC 496 3,000 LBS bird
Ihave another question about my BBC 496 littal street time more 8th time Iwont to use the DART PRO 1---119 combustion chamber 325 intake runner , compression ratio 13:1 on 110 gasoline , fuel injection system by HOLLEY COMMANDER 950 RACE , Nitrous Oxide fogger direct port system up to 250 shot and iwont to use a COMP CAMS hydraulic roller what lift should i use ?
Old 08-20-2009, 12:24 PM
In-Zane Moderator
ZONES89RS's Avatar
Depends, how much do you want to give up on driveability? Solid roller will make the most power, with a 496 and that compression you can get 800 HP with the right cam, intake and exhaust.
Old 08-20-2009, 01:29 PM
tickey8's Avatar
Default BBC 496 bird
I wont to drive my bird know more then 5 miles across town to the hot rod shop where we talk about how has the hotest hot rod on the street maybe ones or twice a week
Old 08-21-2009, 01:33 AM
In-Zane Moderator
ZONES89RS's Avatar
Solid roller would really be the way to go then.
Something with about 268/272 @.050, about .660 lift on a 112 LSA.
