On the Bump stops
On the Bump stops
i need some help. My 99 camaro SS is sitting on the bump stops. I have Lg rear springs and koni shocks. The car is sitting on the bump stops, what is going on. Would the springs be bad or the shocks?
Are you actually sitting on the bumpstops or just close to them? Because that might be normal depending on how low the springs are meant to be. The axle when the suspension is loaded is not too far away from the bumpstops on lowering springs.
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F-bodySuspension.htm
Most people don't realize how little suspension travel they have with lowering springs. So if he removes the bump stop spacers he'll regain 1/2" of compression travel which will help. The springs might be bent if they've been on the car a long time, but I doubt it.
What you ride height front, and rear?
Remember, the LG spring do lower more than most lowering springs, the listed drop is 1.5"
Also do you have the rear loaded down with stereo equiptment?
LS1TECH Sponsor
Taking the stops off is not the answer, all you are doing is removing progressive, rising rate wheel rate. You'll "gain" travel, and then things are going to get real nasty when you run out of it (and you will).
I have a few pair of rear springs here that came in without matching fronts. I know they'll work with the front rate just fine, and they'll give you a lot more travel. $150 shipped. What's ironic here is I remember telling you that would happen with those springs years ago--and here we are. Luckily have a remedy for you...
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
