will 15" wheels fit over stock rear brakes?
Old 08-21-2009, 05:22 PM
ricknbird350's Avatar
Default will 15" wheels fit over stock rear brakes?
i have 15x10 rims i bought at summit but currently i have drag brakes on the car. i dont like how aggressive they are and i want to swap someone for stock ones. but im worried the wheels wont fit.
Old 08-21-2009, 05:59 PM
Camaro396's Avatar
What kind of drag brakes do you have? What are you looking to swap for?
Which wheels did you purchase from Summit? Only Weld's R/T Series wheels, and Bogarts Drag Wheels will be a direct bolt on in all four corners.
Old 08-22-2009, 05:27 AM
IWGF's Avatar
Most wheels aren't going to be a direct fit and will need some grinding. I spent 3 hours grinding my calipers for Prostars, and it's still cutting it a little close.
Old 08-22-2009, 08:39 PM
INMY01TA's Avatar
Put em on and try?
Old 08-26-2009, 06:28 PM
i have the sum-521-5162ps they have a 5.5 in backspacing because the rear is narrowed 4".
the rear brakes are u.s. f33i drag brakes. i just want the stock ones in swap. plus money. i would need your backing plates cause these have there own.
Old 08-26-2009, 07:15 PM
adam1803's Avatar
Summit wheels take alot less grinding then prostars, i barely had to gring any to fit over my stock brakes. PM me with what you want for the drag brake setup please.
Old 08-26-2009, 09:56 PM
Camaro396's Avatar
They're also 2x the static weight, made in China, and don't come in a correct backspace for a stock length rear end.
Old 08-27-2009, 02:05 AM
IWGF's Avatar
Which is why I dig my Prostars
