Will the 85mm FTP lid fit under a SS hood?
Old 08-21-2009, 06:12 PM
foreverzero's Avatar
Default Will the 85mm FTP lid fit under a SS hood?
has anyone had any fitment issues? Im getting ready to put in a 85mm maf and i need a lid to match it, and i was just wondering if the FTP lid will fit. my LS1 motorsports lid rubs....
Old 11-03-2009, 08:26 PM
Well I bought the ftp 85mm lid and my hood will not close....at all. Does anyone know how to fix this? I dnt want to send the lid back or swap hoods
Old 11-04-2009, 03:22 PM
javier1730's Avatar
I had the same issue, I bought the ftp ram ir kit and the 85mm lid which in fact is a 98mm lid after intalling everything the hood just would close..so I got so frutrated that I ended up buying a hood
Old 11-04-2009, 03:51 PM
javier1730's Avatar
I had the same issue...I bougth the FTR ram ir kit and the 85mm lid, which in fact is a 98mm lid and after I finish installing everything the hood just would close...so I got so frustrated that. I ended up buying. A hood
Old 11-04-2009, 05:46 PM
thewholefnshow1's Avatar
You have to trim the bottom of the air box where it's sitting on the frame and after that the hood will close.
Old 11-06-2009, 05:56 AM
The part that's sitting in front of the radiator? How much do I trim and exactly where? I just don't want to f this one up
Old 11-06-2009, 07:46 AM
CamaroSS01SLP's Avatar
My TSP 85 mm lid doesn't rub at all but then again, I have a VFN 3'' SS hood so it could be for that reason. Perfect fit & immediately SOTP performance. My gas mileage also increased. I used to get 110 miles on half tank going 75 mph on cruise control. Now I hit 135 miles by half tank so it's a significant increase.
Old 11-06-2009, 02:30 PM
So pretty much I just dremel the whole bottom down an inch or two? That doesn't sound too bad
Old 11-06-2009, 03:21 PM
I would trim to much just trim it evenly a little bit and at the front part of the air box and then put it back on and check and see how it fits and then if you need to trim more then trim a little bit more. I know how you feel I'm on my second lid but my tuner trimmed mine and it doesn't rub at all. I don't know if they broke it the first time or I broke mine. Cause that lid and forcing it shut, something has to give at sometime. I think as said above he has an aftermarket hood that's why he has no problem.
Old 11-06-2009, 04:30 PM
fbodyman1026's Avatar
Was this gain atfer an aftermarket 75mm lid or a stock one?
Old 11-09-2009, 07:54 AM
Yeah, as a matter a fact, the improvement was over an aftermarket lid......It was after I swapped out a "Stealth Lid" that used the Corvette air filter. It was an old type of lid that no longer is in production & the snout on it was very oval & narrow. This was a HUGE improvement......Much happier now......
Old 11-09-2009, 12:11 PM
Did you do it and did it workout for you?
Old 11-09-2009, 06:41 PM
sheikss's Avatar
Can someone post a pic of what your triming?
Old 02-15-2010, 06:49 PM
FrankieD's Avatar
Default FTP lid fitment trouble
Anyone have any pics of what needs to be modified to make the FTP lid fit?
Old 02-15-2010, 09:14 PM
shiv15's Avatar
Mine fits but rubs a little, and occasionally pops the metal clips off. I never thought of cutting.
Old 02-16-2010, 03:48 AM
MASS seller approved
smok'nZ's Avatar
it says on there site it doesnt fit ss hoods that well try a Z28 hood
Old 02-16-2010, 02:58 PM
JScamaro's Avatar
My stock SS hood will close but the FTP 98mm lid does rub a little on the hood.
Old 02-16-2010, 09:05 PM
Moderator
98Aggie's Avatar
The UPD lid clears all hoods.
Old 02-16-2010, 11:34 PM
DrededSS's Avatar
I have the FTP 104, and it rubs a little on my stock hood. That's with the trimming for the ram air kit.
Old 05-26-2010, 06:36 AM
armyboyatc's Avatar
I hate to dig up an old thread but does anyone have pics of what you have to trim so it will fit? Sorry but im havin the same problem
Quick Reply: Will the 85mm FTP lid fit under a SS hood?
