Can all LS6 intakes be used on a F-body?
Old 08-21-2009, 10:10 PM
WS6 John's Avatar
Default Can all LS6 intakes be used on a F-body?
I read that not all of the LS6 intakes are threaded for the throttle cable bracket on the f-bodies.
How do you guys work around this?
Can the intake be threaded if it is from a vette or GTO? I read there is a brass threaded insert in the f-body specific intake?
Thanks in advance,
John
Old 08-22-2009, 03:04 PM
JonCR96Z's Avatar
I think that all LS6 intakes are threaded. If it's not threaded then it's probably a Corvette LS1 intake.
Old 08-22-2009, 03:57 PM
XtraCajunSS's Avatar
There are some early LS6 intakes from the '01-'02 Z06's without the threaded inserts. At some point once GM decided to eliminate the LS1 intake, all LS6 intakes came with the inserts.
Shane
Old 08-22-2009, 09:42 PM
ReApEr75's Avatar
So a LS6 Intake Manifold off a 04 GTO will fit on 98-02 Fbody's correct?
Old 08-22-2009, 09:48 PM
LSX Mechanic
Damian's Avatar
Yes.
Moving this to external.
Quick Reply: Can all LS6 intakes be used on a F-body?
