Textralia Install Question
Old 08-22-2009, 05:21 AM
JoeMack's Avatar
Default Textralia Install Question
Getting ready to re-install a Textralia into my 02 Z28 after motor swap. I have a clutch install write up for a Cartek clutch. Is there anything different between the two? I've tried contacting Textralia for there install instructions with no luck. Thanks for any help.
Old 08-22-2009, 08:02 AM
99ssleeper's Avatar
Installing a clutch, no matter the brand, should only happen one way. Center the disc with the align tool, put the PP on and loctite the bolts criss-crossing the PP as you draw it up. TQ the bolts to spec, I did the factory spec which is 52 lbft. I put a Tex in my previous car with no instructions, did it this way, and had no issues.
Old 08-22-2009, 09:07 AM
1FST-Z's Avatar
