t56 install help
t56 install help
please bare with me im trying to paint a picture so you understand what is going on.
We just got everything together in my brothers 69 camaro. everything is bolted up and ready to go. the last step is to set up the pedals. we were in the process of just lining it up, we were using vice grips so that we could get an idea of where we were going to weld the master cylinder rod to the clutch pedal. we put the rod in the upmost position on the pedal hoping that when we fully engage the clutch it wont be rubbing on the flywheel.
now heres there problem. with the clutch fully engage and that car in gear, when i was rolling it back and forth i could hear the clutch rubbing slightly on the flywheel. is this normal or is something wrong. we have bled it till there were no bubbles in the system just like we are supposed to.
