Need some advice on an ls6 based 402 motor....
Old 08-23-2009, 03:50 AM
IWGF's Avatar
Default Need some advice on an ls6 based 402 motor....
Hey guys, lookin for some advice... I'm looking at doing a:
ls2 block
tsp 402 rotating assembly
custom cam
ported 243's
ls6 intake (for starters, eventually step it up to a fast 90/90)
about a 150 shot of n2o
and of course all the goodies such as injectors, fuel pump etc. etc.
now my question is... what size dish pistons should I go with? Or should I use flat tops? and is anyone running a similar setup? if so, what are the goods? the bads? any recommendations would be much appreciated. keep in mind, i'm not on much of a budget, but i don't want to go all nuts droppin cash.
Last edited by IWGF; 08-23-2009 at 11:14 AM. Reason: Good god, I accidentally said ls6 rather than ls2. Whoops!
Old 08-23-2009, 09:58 AM
ChucksZ06's Avatar
You will have to deceide boost or spray before you pick your pistons.
Old 08-23-2009, 10:55 AM
PREDATOR-Z's Avatar
ls6 block
custom cam
ported 243's
My question would be how do you plan fitting 4.0 bore pistons on a LS6?
Old 08-23-2009, 11:15 AM
IWGF's Avatar
I just saw that I wrote LS6... I meant LS2. I feel very dumb now, even though it was a typo lol. Thanks for catching that.
Old 08-23-2009, 11:16 AM
IWGF's Avatar
Oh, and don't mind my sig... Little behind. I'm going to be spraying the car.
Old 08-23-2009, 12:48 PM
blk00ss's Avatar
I would got with a wiseco -8cc dished pistons. That way you can run a cmaller CC head for a high comp ratio for NA and spray. And if you ever want to go boosted, just swap heads and wham! There ya go. Best of both worlds
Old 08-23-2009, 12:51 PM
PREDATOR-Z's Avatar
Try to find pistons with 2>2.5 cc valve reliefs, that gives plenty PTV clearance for good size cam without milling the heads too much, keeping compresion in the 11>11.4:1 ratio.
I'm partial to Wiseco pistons for price and quality
Old 08-23-2009, 02:19 PM
IWGF's Avatar
Okay cool, thanks for the info. I was thinking of just ordering a rotating assembly from a sponsor, but I could probably piece one together for less...
Old 08-23-2009, 02:50 PM
MelScrilla's Avatar
Maybe if you buy used parts but it seems like 1700-1800 from a sponsor is hard to beat. You figure 1000 for the crank and 500 for the rods and 500 for the pistons your looking at 2000 already without bearings and bolts.
And some sponsors sell bearings and rod bolts with the assembly for less then 2000.
Old 08-23-2009, 04:32 PM
IWGF's Avatar
This is true. I'll see what I can work out though. I'm fine either way, just trying to check out all my options.
