LS? for my buggy
LS? for my buggy
Ok guys, I've been going crazy trying to decide on what engine to build for my off road buggy. Should it be a 408, 427?? or what?? I like big cubes if that makes a difference with these engines.
Some of the things I do know are, forged bottom end, solid roller cam, bushed lifter bores (I do this to all of my engines), Jesel valve train and dry sumped. I am also thinking about having some of the internals coated like pistons, valve springs, bearings and wrist pins, I also like that Katech oil pump they have. Now I don't need this to be an all out racer, just something that will be N/A and good midrange power.
What is a good all aluminum engine that will last. I don't mind spending the extra $$ for good parts, because i don't want to be left out in the middle of nowhere broken down.
Thanks in advance for helping me make this decision.
-Greg
-Greg
Basically for fun in the desert. Not a rock crawler. I use to race dirt bikes years ago and now that I'm older and can't move like when I was younger a desert car is the next best thing.
Honestly, if I can get 600+HP I'd be super happy. What parts will I need to get me there?
generally the 408s are iron blocks i think. the 402s are the alum.
you should have no problem making 600hp at the crank with a built 402. and you should have no reason to go SR.
any number of cams on the market, and a good set of heads to really bring it together. even something like the TFS 215s.
plenty of guys making 500-530rwhp with that setup...
talk to a sponsor
talk to a sponsor
