will 18/19 wheels off a c6 fit a f-body
Fronts bolt right up and rear needs adapter spacer (for OEM C6's).
I have 1" adapter in the front with studs ground down 1/8 for clearence and 1.25 adapter bolted in the rear which puts all the wheels right at the inside edge of the fenders.
If you search you may find negative "china junk" posts about buying ebay spacers on the forum however I purchased 1" and 1.25" lug centric Adapters (5x4.75 - 12mmx1.5 stud) for my OEM C6 wheels on Ebay.
Very simply, they are 6061-T6 aluminum turned to thickness on a laithe and then drilled and counterbored in a vertical mill. I measured mine and the tolerances are very good (within a couple thousanths +/- .0015).
Most importantly they come pressed with 10.9 Metric studs which is the highest strength SAE equivalent stud and lugs nuts.
You can spend more for H&R and the rest but you don't have to IMO!
