241 heads over 853 .. worth the money ?
Old 08-24-2009, 02:52 PM
sayed_000's Avatar
Default 241 heads over 853 .. worth the money ?
hi guys
i'm in the market for new heads for my camaro 2000 ss
and i'm buying 241's heads ...
am asking if they worth the money or not ?
Old 08-24-2009, 03:11 PM
WSsick's Avatar
over 853's no. they are basically the same. you can gt some used ls6's for around $400 and new ones (with small porting) for like $1100 i think. might as well port the ol' 853's if you dont wanna spend ls6 head money.
Old 08-24-2009, 03:17 PM
5.3LJimmy's Avatar
If someone gave you the heads for free it would not be worth the cost of new gaskets and head bolts to do the swap.
Old 08-25-2009, 11:16 AM
dre2013's Avatar
just go with a set of 243's or 799's(same thing). you can find them for cheap sometimes
Old 08-25-2009, 12:23 PM
FST SS's Avatar
my 2000 SS came with 241's.....
Old 08-25-2009, 12:27 PM
kinglt-1's Avatar
Does nobody search anymore? get 243 or 799 castings if you want a cost effective improvement. Goin from 853 to 241, would be like pissin in a 100mph headwind!
Old 08-25-2009, 06:18 PM
SOMbitch's Avatar
243's are easier to find on the Corvette forums than on here FWIW.
Old 08-26-2009, 02:18 PM
sayed_000's Avatar
thanks for the help guys
i got the 241's for really cheap and now i'm looking for 243!
Old 08-26-2009, 02:39 PM
WS6_MAC's Avatar
Arn't 241's stock LS1 heads?
Old 08-26-2009, 02:40 PM
99Ls1fever's Avatar
There is ZERO differance between a 241 and 853 head. Both are LS1 Castings.
Old 08-26-2009, 02:43 PM
MASS seller approved
smok'nZ's Avatar
for some 2000 cars yes all 2001-2002 came with them
Old 08-26-2009, 02:49 PM
jrob56's Avatar
ya mine too, did all 2000's not get 241's?
Old 08-26-2009, 05:49 PM
RedRocketZ28's Avatar
Mine has 853's....
Old 08-26-2009, 05:58 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
If your looking for crazy cheap we offer cnc ported 241s with stock valves & ported to your specs for $600!! They typically go about 280cfm-285cfm on a stock valve/bore setup.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 08-26-2009, 06:25 PM
kinglt-1's Avatar
^damn thats decent! How much more cfm is that over stock 241's?
