my suspension is squeeking please help
Old 08-24-2009, 05:37 PM
lil hector's Avatar
Default my suspension is squeeking please help
my suspension started squeeking and i took it to a shop and they told me it was the ball joints.i went home and changed the out and the car was still squeeking,so i decided to go ahead and change the upper and lower bushings and it still squeeks.i also bought the sway bar bushing kit and installed it and the **** still squeeks i dont know what it can be can yall please help me before i light this bitch up on fire.lol.
Old 08-25-2009, 03:10 PM
Dal1as's Avatar
Did you grease the sway bar bushings, the ones shaped like a D? Could also be the stock shocks if you still have them on there.
Old 08-25-2009, 04:43 PM
lil hector's Avatar
Default hey bro.
ill try to grease the d shape bushing today,i even changed the front shocks and it still squeeks.ill let u know what happens.
Old 08-25-2009, 05:02 PM
Dano50's Avatar
Fluid Film!
Old 08-25-2009, 05:45 PM
Dal1as's Avatar
Originally Posted by Dano50
Fluid Film!
Interesting. Never thought to use that on the suspension. I've used it other places and it's great though. Will be ordering some soon.
Old 08-31-2009, 06:14 PM
lil hector's Avatar
my ride still squeaks after i greased the d shaped bushings on the sway bar.does anybody think it could be my springs?
Old 08-31-2009, 10:10 PM
Animal323's Avatar
does it sound like and old door creaking open? i have some sounds coming from my suspension and i think its the springs to.
Old 08-31-2009, 10:34 PM
eseibel67's Avatar
You changed all 4 ball joints, all control arm bushings, shocks, sway bar bushings and end links.
You pretty well covered everything obvious.
Some far-fetched ideas:
1) Inner tie rod sockets.
2) Upper shock mounts.
3) Caliper bushings.
Also, it might be something non-suspension related. Remember the entire car goes over the bumps. Any metal touching where it's not supposed to will cause a squeak.
Old 09-01-2009, 12:46 PM
lil hector's Avatar
Default hey bro.
i changed the tie rods too.im about to check the shock bushings
Old 09-01-2009, 03:41 PM
Dal1as's Avatar
Also, there is a metal bracket that the sway bar d bushing is attached to, I believe on the passenger side that can come loose and make a creaking sound.
Old 09-01-2009, 03:44 PM
SamhainZ28's Avatar
I had this problem too, turned out to be my panhard rod bushings
Old 09-01-2009, 04:40 PM
lil hector's Avatar
Default k
k ill try that one to
Old 09-01-2009, 08:04 PM
eseibel67's Avatar
Did you change the outer tie rods that attach to the spindle, or the inners that are inside the rack bellows?
It's the inners that can cause a squeak on bumps.
Old 09-01-2009, 08:52 PM
SWEET98SS's Avatar
Hey, mine was squeaking, I thougth it was the suspension, it was actually the rear exhaust hangers, squirted them with WD-40, went right away. Worth a try
Old 09-01-2009, 09:49 PM
lil hector's Avatar
ill try that too,but it coming from the front.im just gonna take it somewhere and tell them to figure it out.ill let yall guys know what it was.
Old 09-02-2009, 09:09 AM
Dano50's Avatar
Have you received a free sample of Fluid Film? It's gonna last a heck of a lot longer than the competition.
Old 09-02-2009, 03:23 PM
Dal1as's Avatar
That's for sure. I just use WD-40 for troubleshooting. The noise usually comes right back. I need to order some more fluid film.
Old 09-02-2009, 07:23 PM
lil hector's Avatar
Default hey
i hope it comes pretty soon cause that noise keeps pissing me off and i feel like catching it on fire.haha...
