NA to Spray, how much MPH did you gain on a 100/150 shot?
Old 08-24-2009, 08:50 PM
gillbot's Avatar
Default NA to Spray, how much MPH did you gain on a 100/150 shot?
Just curious how much MPH the average pickup is with a 100 and a 150 shot? I'd like to know what ballpark i'm gonna be in IF I ever get the time to get this dam kit put on!
Right now my average MPH is in the 118-119 range, with a best of 121 MPH so i'd like to know where i'll be at with a 100/150 shot.
Old 08-24-2009, 09:06 PM
robsquikz28's Avatar
Well typically on a 150 shot you can gain up to 1.3 secs faster in the e.t. But thats with a decent tune and timing pull.
Old 08-24-2009, 09:27 PM
gillbot's Avatar
i'm more concerned with MPH, because I know my PT4000 converter is NOT spray friendly. I don't expect big Et gains but i'm hoping to MPH well.
Old 08-24-2009, 10:50 PM
TravisMcGill2000's Avatar
107 na 120 on 150 shot. just bolt ons
Old 08-25-2009, 01:32 AM
lisy.zhen's Avatar
Old 08-25-2009, 06:57 AM
gillbot's Avatar
Originally Posted by JonCR96Z
What a coincidence. Y'all gain about the same. You even type with the same bad grammar.
lisy.zhen probably copied/pasted since they are a spammer. look at the sig.
Old 08-25-2009, 09:09 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
123 na, 133 n20 150 shot. ran same n20 mile even when car was slower na, so i'm guessing the converter was not the best for nitrous.
Old 08-25-2009, 09:18 AM
ATVracr's Avatar
9.9 @140 N/A
8.8 @155 on 175 shot
The faster you go the less you gain.
Another 175 shot only gains us 5-7 more MPH where the 1st 175 got us 15mph.
Old 08-25-2009, 09:25 AM
jdiddyws6's Avatar
107-119.5 on a 150 here, bolt ons with no converter
Old 08-25-2009, 09:29 AM
gillbot's Avatar
I'm guessing i'd be lucky to gain ~10 on a 150 shot then due to the PT4000 converter. Hmm, not sure if it'll be enough to net me that 10 sec pass......
Old 08-25-2009, 09:44 AM
ATVracr's Avatar
What other mods do you have?
Shiz's brothers car had a 224 cam , bolt ons and 150 shot and it went 10.6's
Old 08-25-2009, 09:52 AM
gillbot's Avatar
i think my converter is gonna kill my spray gains but my build is here:
https://ls1tech.com/forums/dynamomet...4-a4-dyno.html
for the lazy:
Thunder Racing TR230/224 Camshaft
Comp 918 Springs/Titanium Retainers (I have new upgraded PAC springs to go on)
Thunder Racing Hardened Pushrods
STOCK untouched heads (never been off the car)
Full Throttle Speed Upgraded Fuel Pump with Hotwire Kit
Yank PT4000 Torque Converter
SLP Subframe Connectors
"Stock" Catback with Hooker AeroChamber Muffler
Flowtech Cutout with McCord Power Plate
MAC Headers and Off road Y-pipe
Shaner S3 Throttle Body
Home made smooth bellows
Stock LS1 Aluminum Driveshaft
Lakewood Driveshaft Loop
UMI Performance Shock Tower Brace
Slot Car Products Adjustable Lower Control Arms
Trackbird Adjustable Pan Hard Rod
NGK TR6 Plugs
Stock 3.42 gear GM Corporate 10 bolt Rear Axle (from a Manual Transmission Car)
Stock 4L60E Transmission
MTI Clear Airlid
Fram Paper Filter
SLP Underdrive Pulley
Green top 42# ford injectors to go on also
I have yet to install the NOS nitrous kit though. I plan on spraying it dry.
Old 08-25-2009, 10:46 AM
ATVracr's Avatar
Should go 10's EASY. Matt's car (Shiz Brother) was a Dry 150 also.
That converter wont hurt to bad on a 150 shot... if you can get it to hook.
Old 08-25-2009, 10:53 AM
streetassasin's Avatar
I went from a 13.14@106.7 to a 12.39@116.9 with bolt ons and a 100 shot
Old 08-25-2009, 11:23 AM
gillbot's Avatar
My main concern is the converter. I've been thinking about 1st gear lockout but that would kill a lot of the gain. I need to get the kit on and get to the track and just try it. Though without a cage, I'll get the boot for sure!
Old 08-25-2009, 01:00 PM
ATVracr's Avatar
My converter stalls well over 5,000rpm on the motor. Yours will be OK as long as the tranny holds up and you can hook it out of the hole.
Run it and find out.
Old 08-25-2009, 04:17 PM
gillbot's Avatar
Yeah, I need to get it installed and to the track. I think I might go ahead and drop my shift points from 6900 to 6600 and my limiter down to 6800 from 7100 just to be safe.
Old 08-25-2009, 06:22 PM
WHITE DEVIL's Avatar
mine goes from 122 na to 140 on the 150s
Old 08-25-2009, 06:25 PM
ATVracr's Avatar
Move the shift down but not the limiter.
Just set the N20 to turn off at 6800 so there is no chance it will spray on the limiter.
Old 08-25-2009, 07:12 PM
gillbot's Avatar
I'd rather move the limiter down too if there's a chance i'm going to hit it with even more power. I'm still on stock rod bolts and bottom end.
Quick Reply: NA to Spray, how much MPH did you gain on a 100/150 shot?
