Crank reluctor wheel failure?
well the problem does happen ,,,, i just tore down the engine after finding out that the balck half of the 24tooth reluctor wheel seperated from the front half ( basically i had it free spining in there)
it happened mid run and the engine just shut off. tried to crank it and it just would back fire and pop. did the same thing after a cam and crank sensor swap
