what size oil lines??
Old 08-25-2009, 04:54 AM
jomomma's Avatar
Default what size oil lines??
im just trying to see what size oil feed and return i should be using. i have a garrett 85mm. should i use hardlines or is it ok to use -an lines? thanks in advance!
Old 08-25-2009, 06:06 AM
Fireball's Avatar
its perfectly fine to use AN. My 98mm setup uses -4 feed and -12 drain.
Old 08-25-2009, 07:43 PM
euroman's Avatar
you need at least a -10 return line with a nice smooth downward transition to the pan
Old 08-25-2009, 09:03 PM
SchuttsR1's Avatar
-3 or -4 will work fine for a feed line thats just presure feed. The return has to be at least -10. You want to get that hot oil out as fast a possible and the straighter the better. I would only use teflon ss line for the feed line and you can your the regular rubber ss line for the drain.
Old 08-26-2009, 04:29 AM
jomomma's Avatar
ok, thanks guys!
Old 08-26-2009, 09:36 AM
vipvegas's Avatar
What fitting are you using for the return? An AN barb? I dont want to steal the thread but I want to run -10AN return to oil pan just dont know which fitting to tap with so theres no leakage.
Old 08-26-2009, 06:00 PM
blacksi's Avatar
I've been told after getting my turbo rebuilt that the 3an line was too small for even my 76mm.
Quick Reply: what size oil lines??
