low beams out...
Old 08-25-2009, 03:51 PM
smurray's Avatar
Default low beams out...
Both of my low beams are out. Ive tried cleaning the connections on the back of the bulbs as well as the clips but I either didnt do a good enough job or that wasnt the problem. I had a hard time finding something abrasive and small enough to clean out the female connections so it could still be a corrosion issue i suppose. What relay/fuse should i check? My high beams are working fine, as are both motors.
Would it be safe to splice the 5 wires that make up the large square connectors together? Its not something i want to do because i imagine ill have to remove the headlight assys. to get a good hold of the wires but i would rather not have to deal with this CRAP all the time, and that would eliminate the problematic connection altogether...
