A few teaser pics, I am almost done.
The interior, I know it needs a good cleaning, it has been 21 months now.
Under the hood is looking pretty good too. Though I really wish I had painted the inner fenders while the motor was out.
Hopefully it will be running this week.
WOW!
First time I've seen an intake setup like that on an F-body. I hear individual TB's per cylinder are a bitch to tune. Is that only true for carb'd motors maybe?
Anyways love everything in the interior but the shift ****, honestly something less flashy would look better I think. Everything else rocks about the car from what I've seen so far!
Need more pics now!
Need more pics now!
The idle was awesome, I amd using Big Stuff 3 piggy backed on the stock computer to keep the stock gages, ABS, power stuff, AC and the security system.
Here is a video of the dyno pull.
http://videos.streetfire.net/video/L...rop_205445.htm
Thanks for the props.
The little battery is 15lbs, better than adding 25lbs on top of the stock 35lbs to put it in the back, or at least that was the way I looked at it. I likley should have got the 17lb one for a little more cranking power, but I figured it would be an experiment.
BTW I built this thing myself. I had help and input from proffesionals, but if it under performs it is my fault, I strayed from the normal quite a bit. I wanted a fast street legal (including emissions) car that will be an animal on a road course, can be cruised on back roads with the wife in tow, shown at cruise nights and knock off 10s on street legal tires that I can drive on the street up here in Canada with no fear of the police hassling a middle aged guy.
I had always wanted to do a project like this and got a little carried away for my first one. The numbers seemed low to me, but the torque was a little higher than expected. As mentioned above I will be happy to see more than 560 rwhp and 550rwtq. I think I need to port the intake and maybe a little work done to the heads. The new cam was to try and move the powerband up 400-500rpm.
If you want to see the build from the very beginning it can be seen here at a local club I belong too. There are dyno sheets, flow numbers on the heads, my spring and push rod selection. I really expected it to be a screamer, but it was a stump puller instead.
http://forums.tfbm.org/index.php?t=msg&th=5047&start=0&
Learning about fiberglass.
http://forums.tfbm.org/index.php?t=msg&th=6587&start=0&
Thanks again guys, it has been a long 2 years without it.
As for comfort on any trips, I have no idea, since the car has not turned a wheel yet since they went in. They feel pretty good though. I have the optional lumbar. I had to modify the driver side fame to lower the seat by an inch, it was way to high for me with a helmet.
