Brakes??
Brakes??
What are ya guys doing as far as brakes go? I have the option for a 4 channel or 3 channel abs axle mods for my custome rearend. Do you guys use stand alone abs systems? What brake kits? Or just keeping what ya got?
The newer rides. I just have a nervous thing about not having ABS in my 98 since it now has a big block in it. But maybe Ill be ok. I dont drive it much on the streets but I do drive it about everyweekend in the summer time
What tires are you running? Fats and skinnies? Same all around?
Reason I ask, if you are running offset tires ABS is not functioning properly. You'd be better off deleting it and putting a proportioning valve in.
Why not go Manual brakes?
I'm going to start on my brake system tonight and I scrapped the whole brake system and started fresh. This way you can get away from the stupid metric lines.
~Jim~
~Jim~
I have aluminum heads. I know my ABS isn't working. I just wasnt sure what route to go as far as my brake system. I think leaving the ABS system out of the picture is the route im going to take. Ima look into what ya both said and see if I can find some more info about it. Thank you for the advice
