Shift Boot?
Old 08-26-2009, 01:53 PM
8675309's Avatar
Default Shift Boot?
So the clips are broken on my shift boot. I've been thinking of a glue or sealant of some sort to get it back on the center counsel. Would some RTV work? Or just some crazy glue?
Old 08-26-2009, 02:15 PM
rs94z28's Avatar
https://ls1tech.com/forums/appearanc...boot-clip.html
....looks like it's been a while but you could probably pm the guy...
Old 08-26-2009, 05:47 PM
Save the manuals!
wssix99's Avatar
I had the same problem and fixed it perfectly. You just need ABS (pipe) cement. (The plastic is ABS.) Mine broke at a bend in the plastic, so I reinforced the weld with a piece of paper clip and we're still going strong.
The cement can be had in the plumbing department of some hardware stores or from a plumbing supply. (Its cheap also!) Its sold right by the PVC cement and pipe primers. In the midwest, I've seen the stuff at Ace, Menard's, and at industrial plumbing/HVAC/MRO stores.
Old 08-27-2009, 06:52 AM
Save the manuals!
wssix99's Avatar
BTW - Crazy glue or other adhesives will not stick to the ABS. (But the ABS Cement should give you a partial weld, which will increase in strength over 1 week's time.) http://www.acehardwareoutlet.com/(i3...aspx?SKU=44055
If you use the ABS cement, you'll want to let it dry for at least 2 days before installing. (so it can build up strength in the weld)
Old 08-27-2009, 08:53 AM
ss1
ss1's Avatar
I'm pretty sure you can buy a brand new replacement plastic ring from a GM dealership. I bought one a few years ago while a friend was working at one. Unfortunately, I don't have the part#.
Old 08-27-2009, 12:59 PM
Save the manuals!
wssix99's Avatar
They can still be had, but you have to by the whole boot. (The ring is loosely glued to the pleather.)
Old 08-28-2009, 08:01 AM
ss1
ss1's Avatar
I'm sure I bought the ring by itself. I'm sure because I know I don't have an extra shift boot hanging around. Is it possible they stopped selling it this way?
Old 08-28-2009, 01:58 PM
Save the manuals!
wssix99's Avatar
P/N 10306417. GM shows it only as an assembly. $40-75 depending on the dealer.
I normally buy new parts when trim brakes, except for this one. The ring isn't designed well, so I went with the $3 glue and reinforced the problem point. I figured that if I put in a new ring, it would just break again.
