Weld prostars
Old 08-26-2009, 07:33 PM
javier1730's Avatar
Default Weld prostars
I need some prostars for my 98 z28 so im between 15x10 7 1/2 backspacing...15x8..i need to know whats the right backspacing on the 15x8 for and fbody?also will i need to do any grinding?...thanks for the replies
Old 08-26-2009, 10:00 PM
Camaro396's Avatar
If you chose a 15x8 wheel you will need 5.5" backspace. I would stick with a 15x10 wheel though, it really opens up a lot more options tire wise. With a 15x8 you're limited to which tires you can use. Weld Prostars will require grinding and or a spacer. Weld's new R/T line (in sig) is designed to fit over stock OEM LS1 brakes.
