Will a 7 be cold enough?
Old 08-26-2009, 08:19 PM
fastGBcamaro's Avatar
Default Will a 7 be cold enough?
I am planning on ordering my Nitro Daves plate kit tomorrow along with some other accessories and spark plugs. I plan on starting at a 150 shot. I am running a 413 cid LS2 that has 11.1:1 CR. I was thinking that an NGK with a heat range of 7 would be cold enough, but do you think I should go colder?
Old 08-26-2009, 09:48 PM
gator's 99TA's Avatar
7 is what i run with a 150 plate. i think its pretty conservative honestly.
Old 08-27-2009, 07:52 AM
dkbmxer002's Avatar
Yeah I think that you would be safe.
Old 08-27-2009, 12:02 PM
Nitro Dave's Nitrous Outlet's Avatar
The BR7EF will be fine for your application.
Old 08-28-2009, 08:53 PM
ls2 bait's Avatar
7 should be fine. it worked on my 11.5:1 motor on a 200 shot. on a dyno anyways i never sprayed it on the track with the 7's. i know that could def change things.
Old 08-30-2009, 09:01 PM
Thanks for the replies everyone. Guys at the N20 Outlet, you will be hearing from Beyond Redline in Green Bay with my order tomorrow. Thanks in advance, I know this kit is going to kick a$$.
