Harness help
Harness help
Hi, I have a question regarding the modifications to my harness and I hope that some of you who have done it can help me.
I think I have all the connectors and wires figured out -that remains to be seen , however I have wanted to connect all injectors to a single fuse per bank. However I have not been able to find PINK cable in a thicker gauge (14) to join all the cables together, and that is the main reason my harness modification has remained dormant for some time now.
Well, I want to finish it, but I cannot find the wire in the color I need, and my question is... Can I interconnect (solder) the injector positive pink cables to a single one? ... Will a single thin wire (16 or 18 gauge I believe) be able to carry power for all injectors with no problem? ... Should I forget color coding and use a RED 14 gauge?
I intend to do this for the coils too and get rid of all that redundant wiring...
I would appreciate any input on this.
Thanks a lot
Rat Chevelle
Thanks a lot
Rat Chevelle
www.waytwkwire.com should have the wire, but you'd have to buy a whole roll. I think EFI connection sells wire by the foot. You shouldn'd need a real heavy wire, since only one injector or coil fires at a time. I think I use 16 gauge
1 Post
