how is everyone hanging their TSP true duals
Old 08-27-2009, 08:43 AM
sscamaroburn02's Avatar
Default how is everyone hanging their TSP true duals
Okay last night i got my tsp duals with bullet mufflers mounted up and loosely fit. My question is what is everybody using to hang it with. Are you guys going from the inside of car and using a bolt with matching nuts and washers or using the stock hanger bolts (self tapping) and just bolting it up from outside of car. The stock hanger bolts look rather short and was wondering if they would hold the full weight of the duals okay???
Also I loaded the rear end while installing, how close to the stock torque arm does the system fit??
Anybody pics are appreciated also.
Thanks in advance.
Old 08-27-2009, 10:54 AM
twitchtwice's Avatar
a lot of people use the passenger seat bolts
Old 08-27-2009, 11:03 AM
how do i get to those? do i take out the rear seat and pull up the carpet?
Old 08-27-2009, 11:06 AM
PAGregSS's Avatar
Actually, it's the seat belt bolts that most folks use. You can see the oval shaped plate underneath the car where the bolt goes through. Myself, I pulled the seat bottoms out and drilled a hole on each side. Used fender washers on both side for reinforcement, then put a bolt through.
Old 08-27-2009, 11:09 AM
what size bolts do i use?
Old 08-27-2009, 11:17 AM
ninetynineta's Avatar
I just installed mine a few weeks ago, but my car is just a play car.... not really worried about it being a show car.... I just got everything into place and used the mount on the muffler as a guide and drilled straight thru the floorpan and and carpet and everything, then removed the bottoms of the back seats and ran a bolt straight thru and used a locking nut on the inside of the car.....
Old 08-27-2009, 11:21 AM
how close to the stock torque arm are you putting the mufflers. mine is as close to it as i could get with the rear end being loaded
Old 08-27-2009, 11:25 AM
PAGregSS's Avatar
I can just fit my finger between the driver's side muffler and the torque arm.
Just use the size bolt that the exhaust hangers have holes for.
Old 08-27-2009, 03:15 PM
so it looks like the best way is to mark the hole once the hanger is where its suppose to be. drill the hole out and put a bolt with washers and a locking nut.
thanks guys
Old 08-28-2009, 12:52 PM
do the seat belt bolts have a star head on them? am i looking at the right ones
Old 08-28-2009, 12:57 PM
sorry thanks for correcting me, i meant the seat belt bolts. they are inside the tunnel by the ds
Old 09-02-2009, 08:03 AM
update: got my true duals installed and everything looks good. Exhaust tucked up nice and it looks like I actually have more clearance that I did with my y-pipe setup. Sound is a world of difference compared to old setup. Tone is much lower and just sounds awesome.
I will get some pics loaded and a clip hopefully this weekend.
Old 09-02-2009, 09:18 AM
PAGregSS's Avatar
Cool. Glad to hear it worked out. I like mine a lot more with them extended out the back. Car actually got louder from behind since the sound is now more directed, rather than just reverbing out from under the car. World of difference inside the car.
Quick Reply: how is everyone hanging their TSP true duals
