what will this cam make did i get screwed??
Got this cam in a cam kit from a member on here who told me the cam was a 232/236 .589/.589 on a 113 lsa but it turned uot it was a 232/236 .579/.579 on a 114 lsa with full bolt ons will this still make good power????
Should be looking at 400 to the wheels if not more in a M6 car...
Just did a Lunati Voodoo cam in a 99 Z28 M6 car with midly ported 241 casting heads. Haven't put it on a dyno yet, but with a decent street tune, its making an edjucated guess of around 410-420rwhp.
His cam is:
# Advertised Duration (Int/Exh): 282/288
# Duration @ .050 (Int/Exh): 232/238
# Gross Valve Lift (Int/Exh): .599"/.601"
# LSA/ICL: 113/109
# Valve Lash (Int/Exh): Hyd/Hyd
# RPM Range: 2400-7000
You should be happy with that cam.
His cam is:
# LSA/ICL: 113/109
