Dyno Guesses & Bench Racing Forum - LQ9 under the knife soon
Gaunt
08-27-2009, 06:29 PM
Alright people, car is going in tomorrow to get my LQ9 put in.
Stock 6.0 liter cubes
Stock 317 heads
Predator Z cam 230/228 .592/.588 110-1 LSA (9 degrees of overlap :D)
Lid
1 3/4 stainless headers
TSP true duals (sweet thunders)
3600 edge racing stall (4L60E)
LS6 intake manifold
Random free mod here and there.
What am I putting down? With my boltons and this same stall, it did 330 hp 340 tq in 95 degree weather in the shade.
If you get it right, I will paypal you $1 :P
Gaunt
08-28-2009, 06:30 PM
No guess, even for a dollar?
RaggedRides
08-29-2009, 04:40 PM
Definitely stronger than an LS1, especially considering the torque and fact that it still made those numbers through a stall. I got no idea what it'll make, but keep us posted. After I get my money under control, I'll be slowly going your route.
Why the choice to stick with 317s? Budget?
jetlag
08-29-2009, 06:11 PM
378/381
If I win, I'm going to need $1.03 to cover paypal fees.
Gaunt
08-30-2009, 01:06 PM
Budget yes as far as the 317s go, and I'm not entirely sure on which direction I want to go for future power actually...
Everyday it changes between forced induction and a crazy ass NA build... So it would a shame if I spent the $2k on a nice set of heads and regret it.
And jetlag,
Paypal fee will be accounted for ;)
WYATT318MOPAR
08-30-2009, 01:34 PM
378/381
I can't see it going that high with really just a cam and headers on stock compression. The stall will eat up some anyways so I am leaning more toward 350hp/362tq. You should have a little room for milling, then if you decided to go boosted later just add back the room for lower compression with thicker gaskets.
NemeSS
08-30-2009, 03:27 PM
whats wrong with 317 heads? they are basically the same thing a s 243 799 head but with larger chamber. the 243 and 799 have the benefit of acheiving higher scr. other than that. same thing.
in a 370ci .030 over lq4 i put togther with stock milled 317 heads, lpe gt11 cam, full bolt ons and makes 416rw thru stalled 60e. cam is less than 220 duration on intake
NemeSS
08-30-2009, 03:31 PM
stock lq9 is 10:1 stock, so if he mills and uses thinner gasket such as ls9 it will significantly raise the scr and improve the quench area. its possible to achieve up to 10.6:1 with milled 317 and thin gasket.
although if he does that, then has to account for ptv and will have to machine in relieves to the pistons for correct install.
Gaunt
08-30-2009, 06:58 PM
Oh yeah, I have thought about that for sure, but it really isn't fitting into my Summer budget, otherwise I would have done something along those lines.
However, I have no desire to worry about PTV clearance so that removed it from the equation as well.
I think my power goals would be out of reach from a set of 317s if I was to do something NA build related, but boost related, I know they could get the job done (Obviously it has been done many times in the forced induction section).
WYATT318MOPAR- I'm genuinely interested for your reasoning on such a little leap in power. It looks like you have a 6.0 from your sig, so that's why I ask. I mean, I don't put too much effort it trying to achieve dyno numbers for number contests, but keeping same compression, bumping up the cubes and adding a mild/medium cam only would give me 20 hp/tq?
WYATT318MOPAR
08-30-2009, 07:28 PM
Your only gaining like what 15 cubic inches and a mild cam. I know my car is a different animal all together because my tranny cannot be locked during a pull with it being a 400th. My engine is also pushing 11.6:1 and only puts down 374hp at the wheels. I just don't see you gaining that much with so little changing and no leap in compression that is what really wakes these 6.0's up. I am also maxing out the current set of 28.8 injectors in the car "36's on the way" which is normally something that happens in the 420-430 rwhp range. Don't get me wrong it will be a torque motor and probably a blast to drive. I am actually looking forward to see what it does put down just to see if I am close. I don't know what you were really shooting for as you keep talking about going forced induction.
Gaunt
08-30-2009, 07:52 PM
Yeah, this setup is something to hold me over for the interim while I get something more concrete as a route for power. I know that I'm turning it into a 408. I am considering either doing a d1sc setup after, or a significantly worked L92 headed higher compression motor. Both radically different from
one another, but they will achieve what I want. I want to drive in both before I decide.
I would be more than ok if it dynoed a number like that, but doesn't everyone hope theirs are just a little extra :P kind of in that hopeless optimism boat right now lol :/ realism wouldn't hurt though.
WYATT318MOPAR
08-30-2009, 07:59 PM
I have been hard shopping on some L92's but the intake choices really suck in my opinion don't really want to even think about a L76, I hate Fast and would never pay that much for an intake that was plastic, leaning towards either a sheet metal or something along the single plain line if I can find such a thing. My top end is really holding me back right now I feel like the LS6 is choking my motor on the big end but based of intake pressures on the dyno the tuner says no. Told me the other day that a fast 90 setup would probably only net another 20rwhp that is a lot of cash for a little gain in my opinion. The car runs great I keep changing things so haven't really got to the track all year went to a little 300 ft track last week and got rained out shooting for low 4's on motor.
Gaunt
08-30-2009, 09:06 PM
Yeah, I have people that say the LS6 intakes don't get enough credit, and those that say switch it for a FAST asap. Ported LS3 intake was the intake I was assuming for the L92s however, but I'm not sure how expensive that was in relation to the FAST (or performance for that matter)
AznMuscle
08-31-2009, 11:15 PM
360/370. If I win...just give me that shit sometime lol. And only 9* overlap? Step up your game lol.
Gaunt
09-01-2009, 12:28 AM
Haha, if you win, I can hand over the winnings in person ;)
My game can't step up any higher right now :( It's my DD to Tempe :(
AznMuscle
09-01-2009, 12:50 AM
My DD has 23* overlap :lol:. Only 242/248 duration as well.
Gaunt
09-01-2009, 11:52 AM
Damn you :( Stealing all my thread thunder with your nonsense! In other news, if you ever feel the urge to go to firebird in the coming months, let me know.
:cool:
AznMuscle
09-01-2009, 12:14 PM
:cool:
Hopefully I can get my 16s from back home, and throw some DRs on it, and I'll be down. 1st is useless on the street, let alone at Fireslick. I want to make it out to SW one day...but fuck that is a drive for us. Will your car be done by Thursday?
Gaunt
09-01-2009, 12:17 PM
Ahh, probably not done by thursday. Optimistically, I'm looking at the car being done Friday night/ Saturday morning, then tuning immediately after. Still need to sort out finding a set of M/Ts.
I don't think Nittos are going to cut it for me and my stall anymore :/
Oh also, firebird has decent track prep, but I've always heard SW was the worse of the two (I haven't been to SW, so I can't comment too much on it... and I refuse to drive up there regardless).
AznMuscle
09-01-2009, 02:29 PM
I hear SW is better then Firebird. Either way....both beat the shit out of SIR.
Gaunt
09-01-2009, 02:45 PM
I guess I could do at least ONE trip out to SW to try it out....
Fuck SIR though, agreed.
AznMuscle
09-01-2009, 03:19 PM
Please don't tell me you went all the way to the other side of T town to race there? That just isn't worth the drive unless there is a meet or something....
Gaunt
09-01-2009, 03:21 PM
Originally, I was a student destined for U of A, and not ASU.
Decided against it, but I was down in Tucson for the weekend.
WYATT318MOPAR
09-01-2009, 04:22 PM
Get any dyno #'s yet?
Gaunt
09-01-2009, 05:04 PM
Engine is just now out of the car :P
numbers should be incoming saturday
AznMuscle
09-01-2009, 05:24 PM
Ahh, almost a wildcat. Thats cool. I honestly should have looked at UA more, and looked at their classes. I know more people in Tucson, and actually know my way around there lol.
Gaunt
09-01-2009, 05:32 PM
Here is some glory shots.
My engine was a bit dirty... had a leaking gasket that decided to spray oil everywhere (which is what started this whole process... leaky gasket = new LQ9 in my mind).
AznMuscle
09-01-2009, 05:35 PM
My leaking gasket=H/C set up. Not enough money for a lq9 or anything at the time :(
Gaunt
09-01-2009, 05:38 PM
My heads will be coming along in due time... I still need to iron out my power goals though.
I really really really want to do a NA setup for the simplicity of it, but it would be a shame to let the iron block off easy.
AznMuscle
09-01-2009, 05:50 PM
Boost for DD. As much as I love my cam, I miss the drive ability and gas mileage. Boost...feels like stock till you build rpms and load, then it just screams.
Gaunt
09-01-2009, 05:52 PM
Yeah, I think that's what I'm leaning towards more and more....
I think I'm going to do it all in one big bang sort of thing, so I don't have to torture myself by driving around a low compression 408.
I'm thinking of hovering around 9-9.5:1 compression, D1SC to feed my shit. I haven't looked into turbos too much, other than I want to avoid a rear-mount.
AznMuscle
09-01-2009, 06:15 PM
Do you want ac still? I am assuming yes...
WYATT318MOPAR
I will try to contain myself till then, sure bet you are excited though. Are you gonna be there when it first fires up or after they get the coolant bled out and all that boring time consuming stuff.
Gaunt
09-01-2009, 06:22 PM
I don't think I can be there for when it first fires up, but it will be captured on youtube (I think). It doesn't even come close, but at least it's something.
Also AZN - I do plan on keeping AC yeah, I know there are both supercharger and front mount turbo kits that let you keep it(100% sure on supercharger, 75% sure on Front mount setup). Might have to attack my bumper with some power tools, but I know it has been done :P
AznMuscle
09-01-2009, 06:43 PM
Eh...go blower then. You CAN fit a front mount turbo...but I was gonna tell you go big or go home lol. Most front mount turbo DIY or something requires no ac/heater unit.
Gaunt
09-03-2009, 12:10 PM
Car is running, will be at the dyno Saturday morning :D
Gaunt
09-04-2009, 03:53 PM
Woot!
It lives!
http://www.ls1tech.com/forums/generation-iii-internal-engine/1173417-pred-z-cam-lq9-idle-clip.html
Moving all discussion into this thread :)
Gaunt
09-05-2009, 03:23 PM
HAHAHA wow.
You all lose the bet :(
http://i681.photobucket.com/albums/vv176/dgoulian/DynoGraph.png
AznMuscle
09-06-2009, 01:54 AM
I love that torque graph. Nice numbers. So what are plans from now on? I wanna hear this thing is person...
Gaunt
09-06-2009, 05:40 AM
Not sure of plans, nic d said a front mount, even with these stock cubes or a forged 370 would be pretty fun :P 550-600 to the wheels would be a fun daily! I will probably see you around man, we should definitely do something sometime though ;)
AznMuscle
09-06-2009, 01:56 PM
I'll be back in Gilbert Monday. I just don't know what time. A front mount would be mad fun. For being local with a close guess, you could still give me that $1....lol.
Gaunt
09-06-2009, 02:43 PM
Haha, if I see you, you will get your $1.
AznMuscle
09-06-2009, 03:38 PM
Sweet! Currently more than what is in my wallet :(.
