pro-magnum roller rockers
Old 08-27-2009, 09:19 PM
Blue92coupe's Avatar
Default pro-magnum roller rockers
Has anyone got the pro-magnums to fit under a stock valve cover.
Old 08-27-2009, 09:39 PM
WeathermanShawn's Avatar
I did (previous set-up).
I also suffered some serious valve float right after install. I went back to stock rockers on my current set-up. I have no problems now.
Good luck..
..WeathermanShawn..
Old 08-27-2009, 10:13 PM
srpoweredcoupeNWH's Avatar
I love mine the only thing is I had to pull the baffles out from the valve covers and grind just a little underneath where the bolts are for the coil pack brackets
Old 08-27-2009, 11:09 PM
wicked z28's Avatar
I had valve cover spacers on mine.
Old 08-27-2009, 11:52 PM
thanks for the responses guys. Im wondering if my pushrod length is wrong because it seems like they are not even close to fitting.
I bought these 317 heads used and they came with a turbo cam, lifters, pushrods, rockers, the whole top end. the guy I bought it from had it on a 5.7 and im putting it on a 5.3, so I guess i need to measure the pushrod length. I cant get ahold of the guy to see if he had to use spacers. Does anyone know what the best deal on some spacers is??????? thanks again.
