need help!! car has to much crank case press.
my car has been driving find, yestr day i was checking things out and it seen that the car had alot of crank case pressure. well 2day it has more pressure. and the car is smoking now.
whats up!! y is it doing this out of the blue?
When you remove the oil cap w/car running does oily smoke come out? If so, then it could be failed ring land or hole in piston. If white oily air, then blown head gasket. Hard to say for sure, but if pressurized air comes out w/cap off it's likely one of these issues.
i have the ls1 pcv, witha new pcv valve,, well it looks like the crank case press had blew out my rear seal caues it looks like its leaking. with the oil cap off ALOT of white smoke is comeing out and white smoke is comeing out the tail pipes to!!!!!
maybe this will help, the white oil started comen out with the oil cap off, just alittle at 1st but now its really comeing out and the car is smokeing out the tail pipes, at 1st it wasnt smoken out the tail pipes. if it was a head gasket the car would have started smoken rite away???? yes or no
