Bolt-on guys what do you have for shift points and rev-limiter
I watched my car today and it looks like it is shifting 5800-5900 RPM and the rev-limiter is about 6200 RPM. I have hit that rev-limiter several times now and it usually messes up my runs. Well a Predator is on the way and I want to adjust those settings before I go down again. What is everyone else using and how high can I go on the rev-limiter and stay safe?
2 to 3 at 6100
Hopes this helps you.
Check your valve spring card ,and see what the max rpms they allow.. The lift is mostly for coil bind & cam lift. I shift at 7200rpm and rev.limiter at 7400rpm running a .690" lift spring on a .665" lift cam ,and i can tell when my spring are getting weak when it start to valve float around 6900rpm. I would set the rev. limiter at 6400 rpm and shift at 6100 rpm. Are you running a auto or M6 ?
