Engaging without pedal....
Old 08-30-2009, 11:55 AM
Mr. Luos's Avatar
Default Engaging without pedal....
Installed new clutch.
Buttoned everything up.
Used my old slave (with 11K miles, updated version...will probably be replacing).
Bled system.
Pedal all the way down, put in 1st gear, and without releasing the pedal, the tires will start to spin.
Put it back in neutral, release pedal, move shifter towards first gear....and they start to spin there as well.
Is this a slave issue (current one got covered with oil)??
Or maybe it needs a different shim??
TIA!!
Old 08-30-2009, 11:59 AM
nmass399's Avatar
I would say get a tick performance master, new slave and a shim. Sounds like your slave is too far away from the pressure plate or its just dead. Its nice to have a master cylinder like ticks that you can adjust.
Old 08-30-2009, 12:03 PM
rice8er's Avatar
don't buy any of that stuff yet. what brand of clutch? did u do any measuring be4 u put it together?
Old 08-30-2009, 09:53 PM
Mr. Luos's Avatar
Not sure the clutch brand matters....but it is a 4+
Didn't measure, used supplied shim with new fly, PP, and disc.
Old 08-31-2009, 08:41 AM
Gen414's Avatar
That is NORMAL. How fast are they spinning? Put your foot on brake...what happens?
Old 08-31-2009, 12:15 PM
Mr. Luos's Avatar
This confuses me a bit.
When the clutch pedal is in, shouldn't it NOT spin the tires? I know they would get going...
No idea about hitting the brake.
Pulling the tranny down this afternoon and putting a new slave up.
Old 08-31-2009, 12:19 PM
Grifter's Avatar
The wheels may move slowly(when off the ground) with the clutch pushed in or in neutral. Just did a clutch and all new components on my car and it did the same thing.
Old 08-31-2009, 01:19 PM
Mr. Luos's Avatar
Heading to work on it again in a few hours...
I will check.
I do hate leaving it like this though....
Old 08-31-2009, 01:41 PM
bearcatt's Avatar
Yes it does matter especially if it's a Spec, Ram or some others.
Measuring is imperative unless it's a Monster clutch. Monster's are designed to not use a shim.
They test every unit for consistency and precision before they ship them out.
Why would anyone use an old slave with 11K on it ?
Old 08-31-2009, 01:48 PM
andrew69_04's Avatar
put it down on the ground and then try it before you start pulling it all apart again.
Old 08-31-2009, 05:26 PM
Mr. Luos's Avatar
Severally limited funds.
Old 08-31-2009, 05:38 PM
bearcatt's Avatar
Bummer days.
Old 09-01-2009, 01:56 AM
Mr. Luos's Avatar
Bummer days.
Yup.
Oh well....it ended up getting a new slave. Although it probably wasn't required
Got it taken care of tonight. After dropping the tranny 3-4 times.
Public Announcement....
ARP Pressure Plate bolts DO NOT fit the SPEC 4+ pressure plate.
Old 09-01-2009, 02:06 AM
bearcatt's Avatar
Yup.
I've been there before with the tranny juggling.
Never realized how much fun it could be.
What was the actual cause of the problem, the ARP flywheel bolts not fitting ?
Old 09-01-2009, 02:10 AM
Mr. Luos's Avatar
Yup.
The outer lip of the bolts were actually blocking the disc from spinning freely. So the whole assembly was basicly one....nothing would disengage.
Old 09-01-2009, 02:16 AM
bearcatt's Avatar
Yup.
Wow this is good information.
Sorry to hear you had to go through all that hassle to figure that out.
It must be a good feeling to know you got your car running right again and figured out the problem.
Did you end up just using GM OEM flywheel bolts ?
Old 09-01-2009, 02:20 AM
Mr. Luos's Avatar
Used the ARP flywheel bolts.
Used the supplied Pressure Plate bolts that SPEC sends with the clutch kit.
Old 09-01-2009, 02:23 AM
bearcatt's Avatar
Still with the Spec 4+ p/p or a different p/p ?
Old 09-01-2009, 08:56 AM
Gen414's Avatar
No, not neccessarily, especially with a new clutch. Now, if you hit the breaks, and the motor dies, then you have a problem. But, if tires are just slowly moving, that is perfectly normal.
Old 09-01-2009, 10:54 AM
SPEC-01's Avatar
What were the specs of the ARP bolts you used?
