direct port 4 vs 2 solenoids?
Old 08-30-2009, 02:51 PM
Nimitz87's Avatar
Default direct port 4 vs 2 solenoids?
looking through Nitro Dave's gallery I see 2 solenoid and 4 solenoid direct port setups such as.
what are the pros/cons to each setup? I'm looking at spraying 2 stages, 1 direct port, and 1 plate kit.
150-200 out the whole (whatever I can hook) and then another 150 as soon as possible.
Chad
Old 08-30-2009, 05:13 PM
slammin86's Avatar
Great question. I would like to know the answer also.
The only benefit I could see the 4 solenoid having is if you were spraying such a large amount that one solenoid couldn't flow, and became a bottleneck.
Old 08-30-2009, 05:15 PM
Nimitz87's Avatar
That is the only thing I could come up with as well... then couldn't you just run 2 bigger solenoids?, and what size shot would be a bottleneck?
hopefully the nitrous guru's chime in
Chad
Old 08-30-2009, 05:52 PM
MelScrilla's Avatar
originally i was thinking the 4 was for 2 stages and the 2 was for one stage but after looking closer it seems like your right it may be for large single shots. Or it could be for style maybe some people dont like the lines running across the top of the intake.
Old 08-31-2009, 12:38 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
It really comes down to aesthetics....and as stated before the 4 solenoid will flow more.
But the 2 solenoid kit will still handle 400+HP
Old 08-31-2009, 12:57 PM
Nimitz87's Avatar
Thanks Ray I appreciate the response. awesome looking setups on both!
Chad
Old 08-31-2009, 07:52 PM
FastBlackTA's Avatar
I ran the exact same 2 solenoid direct port in conjunction with Daves 90mm plate and went 8.5s
Old 08-31-2009, 08:22 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
In general it would be flow wise. Think about the BBC nitrous racers that are pushing 1000+ worth of nitrous through their engines. A two solenoid setup isn't going to work for them. I have an SX2 direct port from NX. It runs 8 solenoids, a -8 feed line, and massive bottle valve with a handle on it instead of a ****.
Old 08-31-2009, 09:14 PM
Nimitz87's Avatar
little more on your setup if you wouldn't mind? you were running an FAST intake?
I understand if you don't want to give the spreads, but what where the Nitrous jets on each kit?
weight?
radial?
cubic inch?
heads?
Chad
Old 09-01-2009, 12:58 AM
DopeFedZ's Avatar
I saw that in one of your threads. I though my 4 was a bit much
Old 09-01-2009, 01:53 PM
weight?
radial?
cubic inch?
heads?
Chad
I'd give you the spread but I forgot. Somewhere around a 30-32 nitrous jet.
3400 lbs, 325 drag radial, 402 cube, AFR
Old 09-01-2009, 04:39 PM
Nimitz87's Avatar
very nice, that is all going thru a FAST setup?
what's your SCR?
what where your spraying on the plate?....very impressive numbers basically my goals
Chad
