Drag Racing Tech
Front suspension question
Old 08-31-2009, 12:57 AM
thebulgd's Avatar
Default Front suspension question
'99 Camaro 4xx rwhp, A4, 3600 converter, adj LCAs, rear sa qa1s, short tq arm, 1" sphon rear sway bar, adj. ph bar, 3 point SFCs
Fronts are stock springs/shocks with 136k miles. How good do SA front shocks, 300# springs and travel limiters sound for an upgrade? Thinking with travel limiters DA front shocks would not be needed.
Old 08-31-2009, 01:03 AM
chvypwr31's Avatar
if you plan on racing it a lot i would spend the little extra and get the double adjustable i have double adjustable strange on my car and its a world of difference with the amount of adjustments. thats just my opinion. -tony-
Old 08-31-2009, 08:10 AM
LS1TECH Sponsor
Steve Burger's Avatar
What will you be doing with the car and what does it weigh? I need that to help.
Old 08-31-2009, 08:39 AM
thebulgd's Avatar
havent weighed it. Spare, rear seats, front bumper support, & a/c removed. 1/4 mile car. Also front sway is removed.
Old 08-31-2009, 09:59 AM
LS1TECH Sponsor
I would go DA front shocks. The spring rate will depend on weight. It should be between 275 and 300#s. We can set you up if interested.
