Nick Williams 90mm Throttle Body Question
Old 08-31-2009, 03:41 PM
BIGBEAUTIFULDOLLP51's Avatar
Default Nick Williams 90mm Throttle Body Question
Just bought a Nick Williams 90mm throttle body here on LS1tech....really nice piece and in great condition with one exception: someone (not NW) drilled the throttle plate with a single 3/16" hole. I have no clue why?? First, why was it drilled? Second, I want to correct the hole. I am thinking of micro welding but am worried about warpage. Does anyone have Nick Williams e-mail or web address so I can see if a replacement throttle blade is available? I am also thinking of using epoxy to fill the hole but am hesitant. Thnaks in advance!
Old 08-31-2009, 04:20 PM
LastBlack02SS's Avatar
I'm pretty sure the hole is to regulate airflow at idle.
Old 08-31-2009, 05:29 PM
Default Nw tb
I just want to be clear that the hole is not from Nick Williams...it was drilled pretty crudely with a hand drill. I do think you are right though...the previous owner was trying to add extra airflow when the throttle plate is closed but I do not know why? I thought idle quality or A/F ratios could be adjusted via the computer?
Old 08-31-2009, 09:15 PM
They can be adjusted via the computer. Typically a good tuner can get it dialed in well without having to drill a larger hole, however I have seen on the forums some people say their tuners have done it for this reason. That typically happens with more radical cam setups though. Shouldn't be necessary.
Old 08-31-2009, 09:16 PM
Sorry to be using so many responses, but I'm guessing an epoxy that you can sand smooth would be the best solution if you want to plug it.
Old 09-01-2009, 02:23 AM
Soul TKR's Avatar
epoxy could work... i wouldn't do it myself though. I'd be too worried of that stuff coming loose then going into the engine.
I've heard of some people using a rivet gun...
Old 09-01-2009, 07:32 AM
Default nw tb
Thanks guys....I'm not really sold on epoxy either....I like the rivet idea. I have tried to find Nick William's website or contact info but no luck so far....
Old 09-01-2009, 10:05 AM
veee8's Avatar
Try here....
Nick Williams (704)658-2302
Call one of the sponsors who carry them --------->
Old 09-01-2009, 03:05 PM
Default Nw tb
Once again...you guys are awesome! I just spoke with Nick Williams and he said send it back and he will replace the throttle plate for free...hell of a guy!
BTW...it does come from NW with a 1/8" hole. Nick said somebody just tried to open it up with a hand drill and that is why it looks so shabby....
Old 09-01-2009, 05:10 PM
Sunset01SS's Avatar
Glad I could help. Figured I had to PM you his contact info since I don't believe he is a sponsor here.
Old 09-01-2009, 06:42 PM
Billiumss's Avatar
Stock size hole in a LS1 TB is 5/32.
It must have been drilled out for a big cam. 3/16 isn't too big. If your going to run a decent sized cam, you might want to leave it alone.
Old 09-01-2009, 08:40 PM
Default Nw tb
My LS6 is basically a stock block motor with a Magnuson blower and headers. I don't think the stock LS6 cam is too aggressive...my question is why do we need a hole at all? Can't the throttle position sensor crack the throttle plate open a tiny amount? Just like carbs do? I'm new to the Fuel Injection game...sorry about the ignorant questions but I'd like to understand the principle before I monkey with something...thx
Quick Reply: Nick Williams 90mm Throttle Body Question
